I have recorded a clip from italian analogic tv (PAL system) with a faulty VCR (low cost, not a S-VHS, with mechanical problems I think) and now I have the urgent need to restore the video which is almost incomprehensible!
I have tried with a TvOne-Task 1T-TBC Multi Standard Time Base Corrector from B&H Video and a Terratec Grabster AV400 but the result is not so good.
What type of defect has my recording?
Any suggestion for a possible remedy (hw or sw like a VirtualDub plug-in)?
Here is a clip from the video http://www.4shared.com/file/241618359/f04e9d22/Movie_0001.html
Maybe a line TBC from S-VHS vcr can do better. Get a Panasonic with TBC or JVC with DigiPure tehnology and check. If the recording vcr is faulty the chances are small. No VirtualDub plugin can help you.
OK...
Two questions:
1) Is it possible that my TBC can't the correct the out-of-synch (the time-shift seems very periodic and constant...)
2) Do You know the name of the defect?
Thanks -
1. Not all external TBC fix wavy lines. Datavideo 1000 can`t. Line TBC from S-VHS VCR fix this type of time base error most of the time. Try Panasonic DVD recorder ES10 or ES15 in passthrough mode because these recorders have inside TBC.
2. Time base errors is the name of defect. Apart of tape transport, external interference may be the source of problem or a combination between vcr, external source and capture device.Last edited by danno78; 16th Mar 2010 at 06:09.
restore 27 year old VHS. please help!!!!
By jatink129 in forum RestorationReplies: 24Last Post: 4th Nov 2011, 05:46 -
Super8 > VHS > Restore
By magillagorilla in forum RestorationReplies: 9Last Post: 29th Jul 2011, 09:45 -
Buying Full-Frame TBC: Datavideo or TVone?
By nikgelfi in forum CapturingReplies: 10Last Post: 9th Apr 2011, 12:33 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
Should I restore vhs videos?
By Grace's Mom in forum RestorationReplies: 5Last Post: 19th Aug 2008, 22:24
