Hi,
I've recently bought an external HDD and started converting my entire DVD collection to mp4 using Handbrake, with the purpose of using my PS3 as mediaplayer. This works like a charm, and they all play on the PS3.
Now I've started converting the entire series of Sex and the City (I guess you won't believe me if I told you, that it belongs to my GF ). But for some reason my PS3 tells me that those files are not supported?!?!? Any ideas as to why?
/Defuniac
Thx for your reply. I've downloaded MediaInfo and this is the info it came up with:
General
Complete name : K:\VIDEO\episode_1-1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.19 GiB
Duration : 28mn 56s
Overall bit rate : 5 880 Kbps
Encoded date : UTC 2010-03-16 17:16:16
Tagged date : UTC 2010-03-16 17:34:42
Writing application : HandBrake 0.9.4 2009112300
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 28mn 56s
Bit rate mode : Variable
Bit rate : 5 717 Kbps
Maximum bit rate : 22.5 Mbps
Width : 720 pixels
Height : 544 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 25.000 fps
Minimum frame rate : 6.250 fps
Maximum frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.584
Stream size : 1.16 GiB (97%)
Writing library : Lavc52.30.1
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 28mn 56s
Bit rate : 160 Kbps
Maximum bit rate : 238 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 33.0 MiB (3%)
Language : English
And here's the info from a movie that works fine...
General
Complete name : F:\Mimic.mp4
Format : MPEG-4
Codec ID : mp42
File size : 1.05 GiB
Duration : 26mn 13s
Overall bit rate : 5 754 Kbps
Encoded date : UTC 2010-03-15 19:04:58
Tagged date : UTC 2010-03-15 19:22:23
Video
Codec ID : 20
Duration : 26mn 13s
Bit rate : 5 592 Kbps
Maximum bit rate : 51.8 Mbps
Width : 720 pixels
Height : 544 pixels
Minimum frame rate : 12.500 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.571
Stream size : 1.02 GiB (97%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 26mn 13s
Bit rate : 159 Kbps
Maximum bit rate : 237 Kbps
Stream size : 29.9 MiB (3%)
Language : English
Text
Format : Apple text
Codec ID : text
Duration : 26mn 13s
Bit rate : 0
Stream size : 23.0 Bytes (0%)
Any ideas?
MKV -> MP4 for PS3 script?
By atod in forum LinuxReplies: 6Last Post: 10th Feb 2011, 15:38 -
H264 to MP4 for PS3 or XBOX360
By DVDONE in forum Video ConversionReplies: 4Last Post: 27th Mar 2010, 15:07 -
MKV HD to MP4 HD (PS3)
By m93 in forum Video ConversionReplies: 10Last Post: 2nd Aug 2009, 10:24 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 21:24 -
MKV to MP4 for PS3 Error
By Ravlin in forum Video ConversionReplies: 1Last Post: 5th Jul 2008, 17:38
