I have one blu ray, and it has one DTS HD audio track. I want to in addition to that audio track add an ac3 audio track, and a subtitles track (there is already one subtitles track). I wanted to know if there was a way to add the audio track and subtitle track while retaining everything intact. Such as menus, chapters, pop up menus, etc. Also after i create this new blu ray i also want to rebuild it with Bd-Rebuilder, just a side note in case it changes anything. please help
I don't think any such app exists. You can remux with tsmuxer, multiavchd but you wont be able to keep everything.
multiAVCHD allows you to re-author the disc (if it doesn't contain branched playlists or alternated endings / series). You can add/remove/blank audio/subtitles/etc...
Here is my post about it: http://forum.doom9.org/showthread.php?p=1361598#post1361598
And a guide: http://forum.doom9.org/showthread.php?t=151925
About re-author mode check crl2007's guide and read the notes below:
1) Drag/Load a Blu-ray disc folder and answer to the prompt with OK to enter "Blu-ray re-author mode".
2) Wait for the initial scan to complete (a good idea is to 'save' the project once the scan is done - this way you won't have to wait the next time you want to load the folder)
3) Open "Properties" of one of the playlists
4) Re-author your disc by doing at least one of the following:
* Blank 'fbi warnings', extras, intros, etc... (do not change the trim_end value of 1.033 - it has special meaning for blanking)
* Add/remove tracks to your main movie or features
* Cut/Trim END of a feature/main movie
* Transcode main movie or a feature
In Re-author mode it all depends on the changes you will make. In other words - if you don't change anything you will get 1:1 copy of your original blu-ray disc.
You cannot add titles (files, playlists, etc) or remove existing playlists in re-author mode. Once in this mode you can't go back to normal authoring mode and you'll need to restart multiAVCHD.
When you browse the playlists (Compilation box) you will see information if one is marked for blanking, if it contains IGS menu as a main playitem [menu MP], or as a subpath [menu SP]. In the "Playlist" tab you should see information about main playitems, sub playitems and sub-path types and their corresponding files (for IGS and TextST).
You should not blank playlists which contain menu links, but if such a playlist is the main movie or a feature then you can 'remux' it. It will be marked as [ remux ] once you change any of its properties (i.e. cut end or add/remove/reorder tracks or transcode a playlist). An alternative way to blank a playlist, which is linked to a menu or textST subtitle m2ts, is to remux 1 second of it - enter 1 as trim-end. Be careful what you blank, because you may break the main menu.
Once you're done, close "Title properties", click "START" and choose:
* PLAYSTATION 3
* AVCHD disc (for DVD or BD-R)
* Blu-ray
In PS3 mode you'll get output suitable for USB HDD - it means that multiAVCHD will remux all playlists which contain playitems (m2ts) files larger than 4GB.
In AVCHD mode you will get output suitable for burning to DVD or BD-R disc. You may need to remove some folders, depending on your player specific requirements.
In Blu-ray mode you will get the same as AVCHD but with the original index.bdmv file.
Introducing such feature to multiAVCHD aims mainly to make Blu-ray discs playable in Playstation3 using USB HDD (Blu-ray disc to USB HDD) without loosing any features (except the pop-up menu, which is not supported while playing from USB [edit Feb 16th - POP-UP menu works in PS3 when using the [] VIEW button]. If the disc is BD-J authored, Playstation 3 will not play the USB output. If you use Blu-ray mode and burn to BD-R/RE it will work in your Playstation 3.
multiAVCHD's re-author feature is in no way replacement of or can be compared to BD-Rebuilder's features and reliability, and is also not added with an idea for competition. It should be possible to use multiAVCHD re-authored output with BD-Rebuilder, but if you do and have problems state that you used a re-authored copy, but not the original (which would usually mean a problem within multiAVCHD, but not BD-Rebuilder).
Should your re-authored copy is bigger than 25GB BD-R disc you will need to transcode the main movie or blank some audio tracks. Blanking audio can save you few GB. Transcoding has the same functions as in normal authoring mode. Bitrate calculations in re-author mode may not be correct (showing higher MB/GB requirements). Transcoding to lower resolution will not resize internal PGS subtitles to the new resolution.
In re-author mode features as PIP (Picture-in-Picture) are not supported (yet). Blu-ray titles, featuring alternate endings with branched playlists may or may not work as expected (either one branch will work or you will get huge oversize, having both/all versions in the final compilation). I don't have such titles to test with. TextST (subtitles) should work.
In re-author mode you can add/remove audio tracks, convert HD audio to AC3 or use the SD core of HD streams (to save space). You can add SRT/SUB/SUP/ASS/SSA subtitles, too.
Always make sure you have enough free space and that you are using NTFS partitions for TEMP and destination folders (except when using PS3 mode - then destination can be FAT32).
That's about it.
Have in mind that I coded this feature in just few days, so it may not work exactly as expected, but please test it with your Blu-ray titles and get back to me with the results.
DeanLaugh and the world will laugh with you. Cry and you will be alone -
I've added a audio track to a bd with multiavchd in re-author mode, and after remux the m2ts, when i tried to play with power dvd o tmt it not show the video track when i press play at the main menu, and other hand it shows by the menu the audio added and the other originals but video doesnt starts, if i change this m2ts for the original the bd works again and it has by menu the new audio but obviuosly isn't include into the m2ts file
You can create more than 12 episodes? ... and navigate in the menu of the bluray
Size of blu ray audi track?
By Espo99 in forum Blu-ray RippingReplies: 1Last Post: 31st Jan 2012, 16:24 -
Incorrect track playing on ripped Blu-ray of X-Men First Class
By slickster in forum Blu-ray RippingReplies: 3Last Post: 10th Nov 2011, 08:19 -
Adding menus to a remuxed Blu-Ray
By ITISRAVI in forum Blu-ray RippingReplies: 0Last Post: 17th Nov 2010, 09:27 -
Blu-ray Narrorator Track Question
By chanchett in forum Blu-ray RippingReplies: 2Last Post: 21st Oct 2009, 12:32 -
Backing up DVR HDTV to Blu-Ray w/DVD audio track
By pulsation in forum DVB / IPTVReplies: 8Last Post: 15th Jul 2007, 03:54
