Good day to you.
i have been using jing capture software on a macbook to capture some talking head stuff for work, the demo version only captures in swf and no matter how hard i try i can find nothing to convert it in to a decent format.
on the mac i have tried handbrake but it cant recognise the format, on my xp machine i have tried super and that says it is not a vaild file, however if i play the files in a swf player the video is fine and it also plays back perfectly in jings history.
The files range from 50mb to 200 mb. i di also try swftoavi but it also says at the end of converting that a missing parameter makes the file invalid
if you can offer me any advice i would be most grateful or suggest an alternative freeware capture for the macbook that i so far have been unable to find in google without paying. It has to be freeware as i am using my works macbook and typically there is no budget for software!
sorry i should have been more clear.
i have captured some video from a news website of 'talking heads' to use for examples in camera angles.
so video from another website.
i didnt want to or try to download the original video from the website as i only needed short clips as examples.
any (free) command line tools for converting swf to other formats?
By kkol123 in forum Video ConversionReplies: 1Last Post: 7th Dec 2008, 22:42 -
Newbie question, swf converting
By joppz in forum Video ConversionReplies: 3Last Post: 5th Nov 2008, 08:02 -
Capture SWF / FLV from Website
By foochuck in forum Video ConversionReplies: 2Last Post: 19th Feb 2008, 20:21 -
Any gurus here that know how to capture SWF from the web?
By sdsumike619 in forum Newbie / General discussionsReplies: 18Last Post: 6th Feb 2008, 21:53 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 23:15
