I ripped some Swedish subs from a DVD with SubRip, translated them to English in Google Translate. Great...but when I view the DVD and load the translated subs they are badly out of sync in all players that I've used, (WMP Classic, GOM player, VLC) yet when I select the original Swedish subs that are in the DVD the sync is perfect.
What is causing this?
Many thanks in advance.
Has this method ever worked for you before? I suspect it's an indexing problem. Try converting the dvd to an avi using fairusewizard and see if the avi and the subs synch then. In fairusewizard check the box that says you also want to extract the subtitles.
Thanks for your reply, lowellriggsiam!
Yes, it has worked for me before.
I watch a lot of Foreign film and 90% of the time need subtitles. Some subs I get online (Subscene, Mysubs etc) sometimes needing to shift the subs timing +/- a few seconds but nothing more than that and have successfully ripped subs from DVD and translated them and then encoded them into the original VOB files and they've always worked. But, this time, I've had no such luck.
I will try the procedure you mention and let you know if I am successful.
Thanks again! -
What is your workflow? If you compare the *.srt you got from SubRip and the *.sup-file you authored into the DVD, do the timings coincide or do you have a fault already at that stage?
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
I believe I have sorted the problem out, träskmannen. I have no idea why everything was running out of synch.
I always opt to use this method
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
to place my new subs into the original DVD files, thus keeping the original menus etc, and now it all works fine. I guess it was just one of those things. Thanks for your messages guys!Last edited by migrantwing; 22nd Feb 2010 at 11:05.
DVD ripped to Mp4 with handbrake has sound way out of sync.
By Firewire60 in forum DVD RippingReplies: 4Last Post: 1st Mar 2013, 01:59 -
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 06:43 -
Ripped BD subs in .mkv question
By Benaud in forum Blu-ray RippingReplies: 2Last Post: 5th Apr 2011, 04:38 -
Subtitle sync. to CC ripped from TRP file
By vanderbog in forum SubtitleReplies: 4Last Post: 22nd Aug 2008, 22:03 -
Ripped DVD out of sync always...
By SaintGJR7 in forum Video ConversionReplies: 9Last Post: 6th Jun 2007, 02:17
