Greetings to all readers!
Does anybody of you know of any data video DVD burning software that allows for multisession burning and that also allows for file burning into specific folders that are already on the DVDR (for example, folders from the first session)? For the latter, I mean something that lets me decide where to record the file onto the DVDR, whether that be into a specific folder or, if the case may be, as an independent file outside of all folders.
The only software I know that does this, or at least that explicitly mentions this feature, is "Data Burner SDK ActveX 3.0" here:
http://www.viscomsoft.com/products/databurner/features.html
Nonetheless, this software works on CDR's only, and it is too expensive for me at USD 120.00 . Are you familiar with any cheaper or even free alternatives that work on DVDR's?
Cheers,
Carlos Albert
D-Makberto
Results 1 to 10 of 10
Hi, again!
For those who could benefit with an answer, I would like to share with you the solution I found, namely using "Live File System" with Microsoft's Windows Vista or Microsoft's Windows 7. I don't have yet any computer with Windows Vista or Windows 7, but I hope to buy one this year. In any way, "Live File System" formats any CD-R or CD-RW or any DVD-R/DVD+R or DVD-RW/DVD+RW so that incremental packets can be written to the disc from the hard drive via "drag and drop". This allows users to create, modify, and delete files and directories on demand in different sessions if so desired. A session can be closed so that only the rest of the disc can be added files and so in subsequent sessions. In a similar manner, a session can remain unclosed after finishing it so that the whole disc (the unclosed session and the rest of the disc) can be added files and so in subsequent sessions. If a disc is planned to be used without closing any sessions, it is advised that either a CD-RW or DVD-RW or DVD+RW be recorded since none to these discs have to be closed to be compatible with other computers. Conversely, a CD-R or DVD-R or DVD+R have to be closed to be compatible with other computers.
In point of actuality, while Microsoft calls this method of recording "Live File System", this is known elsewhere as "Packet Writing". Different manufacturers have released their own softwares for "Packet Writing"; for instance, there is Roxio's "Drag-to-Disc" (formerly known as "DirectCD"), Nero's "InCD", and Sonic Solutions' "Drive Letter Access". However, for the most part, these softwares have many bugs and incompatibility issues with Microsoft's Windows. For its part, "Live File System" marks the first time that "Packet Writing" is native to Windows, and as such, this provides better compatibility for Windows users.
I hope this information has been useful.
Any comments are more than welcome!
Thumbs up,
Carlos Albert
D-MakbertoLast edited by Disco Makberto; 17th Feb 2010 at 23:30.
All well, Baldrick!
Any comments from this other forum?
Carlos Albert
D-Makberto -
Multisession DVD Burner and Burning Files into Specific Folders
(NO packet writing, just actual multi-session recording).
Sadly ImgBurn doesn't support multisession. -
I think Packet writing is best reserved for post-office's and birthdays! As a technology I reckon its had its day. Its far easier these days, to just write and re-write complete std DVD images onto re-writable discs. I used to use packet writing and had so many data failures I gave up on it. Plus the speed aspect (Too slow) and the loss of data space (2/7ths approx) and you had to make sure the recipient had the correct software running on their machine. Worthy try, but give me a flash drive or a burnt DVD, for compatibility, any day
You cannot use multi-session for DVD-Video -- just data.
Thanks for all replies!
El Heggunte, unfortunately, Prassi Ones Web-site does not mention how to do multi-session recording. Do you have a short how-to?
RabiDog says,
"Its far easier these days, to just write and re-write complete std DVD images onto re-writable discs."
And I agree with you, if you mean a disc-to-disc copy. But that is not what I intend. I am talking about files, a music video clip file, for instance, to be recorded onto the disc. Then, record another file a different day. (Please refer to my first post for detailed explanation if you want).
Have you tried "Live File Disc"? It has been said that this method is supposed to be better as opposed to traditional packet writing.
"and you had to make sure the recipient had the correct software running on their machine".
The recipient is myself, no one else.
"Worthy try, but give me a flash drive or a burnt DVD, for compatibility, any day".
I agree, but if I can read a "Live File System" disc on my computer, that is more than enough compatability for me".
LordSmurf says:
"You cannot use multi-session for DVD-Video -- just data."
Indeed, LordSmurf! I believe "Live File System" uses different versions of UDF as data.
Thumbs up,
Carlos Albert
D-Makberto -
Thanks, El Heggunte! The trick again is not to close any sessions because I'll be adding files to both old and new sessions. I will be comparing this "real burning" method to the "Live File System" method when I get my new computer.
Thanks again,
Carlos Albert
D-Makberto
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
help recovering DVD folders n vob files from deleted hard drive
By grafixx in forum ComputerReplies: 1Last Post: 16th Jan 2010, 14:44 -
Burning multiple remuxed folders to discs, playable as dvd
By blue2 in forum Authoring (DVD)Replies: 6Last Post: 8th Oct 2009, 09:05 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
