  1. Hi,
    Is it possible to play embedded DVB Subtitles (as bitmap) in a MPEG trasport stream with MPC? Any response will be appreciated..
    Thank you in advance
    I don't think so. But MPCHC(beta version) supports DVB subtitles
    Revision 1335 - Directory Listing
    Modified Wed Nov 11 19:16:30 2009 UTC (3 months ago) by casimir666
    Added : support for DVB subtitles
    DVBViewer supports playback of both DVB subtitles and teletext subtitles in MPEG ts streams.
  4. Originally Posted by Baldrick View Post
    Yes, I know that mpc-hc is supposed to support DVB subtitles (after version v1.3.1335.0) But I couldnt find out how should I configure the player to be able to playback DVB subs. Have anyone ever achieved to see DVB subs with mpc-hc?
    I forgot to mention that VLC support DVB subtitles.
  6. yes fk, I know VLC does the job. For some reason we need to use MPC-HC as player. So I need to find a way to see DVB subs with MPC_HC.
  7. Member Budman1's Avatar
    I know this is an old thread but in case anyone still needs the info and reads this. I installed MPC-HC and tried a TS video with DVB subs.
    General
    Complete name : C:\Users\Bud\Desktop\test\The Secret Caribbean.ts
    Format : MPEG-TS
    File size : 43.8 MiB
    Duration : 1mn 48s
    Overall bit rate : 3 389 Kbps
    Video
    Menu ID : 8261 (0x2045)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Codec ID : 2
    Duration : 1mn 47s
    Bit rate mode : Variable
    Bit rate : 3 028 Kbps
    Maximum bit rate : 15.0 Mbps
    Width : 704 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Active Format Description : Letterbox 16:9 image, with alternative 14:9 center
    Frame rate : 25.000 fps
    Standard : PAL
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 1mn 48s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : -291ms
    Stream size : 2.47 MiB (6%)
    Language : English
    Text
    Format : DVB Subtitle
    Codec ID : 6
    Duration : 1mn 44s
    Delay relative to video : 1s 632ms
    Language : English
    Menu
    Duration : 1mn 48s
    List : 520 (0x208) (MPEG Video) / 521 (0x209) (MPEG Audio, English) / 523 (0x20B) (DVB Subtitle, English)
    Language : / English / English
    Turning on and off subtitles had no effect. I already have directvobsub installed but that didn't help either. The only way I finally found to get subtitles to show was by setting Play --> Filters --> Lav splitter source and select the subtitles. Lav splitter was installed as part of my K-Lite codec pack but are available from their download site http://1f0.de/lav-splitter/ . I have not installed from this way, only from the codec pack.
Name:	ScreenHunter_227 Oct. 21 01.27.jpg
    Subtitles show as :
Name:	ScreenHunter_228 Oct. 21 01.42.jpg
    The setting seems to reset every time I ope MPC-HC but at least it works in case anyone is still looking.
  8. Thank you Budman! You know what, I was still looking for this solution. Now after almost 3 years I got the solution. Thank you indeed..
