Results 1 to 13 of 13
    I open .avi files in Stream Clip and it plays audio perfectly but shows no video, only a white screan. Why is that?
    Installed I have:
    have Quick Time v. 7.1.6
    3ivx MPEG 4
    ffdshow
    XP Codec Pack
    Thanks for any help.
    ANd what is the video codec in the avi? identify using mediainfo.
    I used GSpot instead and it says:
    CODEC: mp42
    NAME: S-Mpeg 4 version 2
    and it also informs that 'codec(s) are installed"
    mpegstreamclip doesn't use the same system (directshow or vfw) ; it uses a separate one based on quicktime API. You have to be able to open that file in quicktime, in order for it to work in mpegstreamclip. There are some plugins that you might be able to download, but none of them are free
    So you can open that video in other programs, such as virtualdub, or players such as MPC , but not mpegstreamclip.
    Thank you for your comment.
    It looks strange because for some time I was able to play .avi clip compressed with "XviD ISO MPEG-4" but not the avi file compressed with "S-Mpeg 4 version 2".
    Then I opened Xvid file in Avidemux and since then it all messed up in Stream Clip. It only opens audio, vido is blank.
    Exactly what are you trying to do?
    You should be able to open it up in vdub, if you have mp42 enabled in the ffdshow vfw configuration (gold icon)
    You should be able to play in a direct show player like MPC if you have mp42 enabled in ffdshow configuration (red icon)
    I want to open .avi Divx in StreamClip, edit it and save as Divx and then be able to play it in stand alone DVD player.
    In a compression menu in VD I can see Xvid MPEG-4 codec but no Divix.
    Sorry if I sound ignorant but I'm not that advanced in video processing.
  8. Originally Posted by al2502 View Post
    Not in MPEG Streamclip and especially not in PC (Windows) version.
    Because MPEG StreamClip uses QuickTime - and QuickTime for Windows does not support MS MPEG-4 and Xvid.
    Because you do not have it installed.
    But usually you can use Xvid instead DivX (can even use ffdshow VfW).
    VideoAudio.pl - Serwis o technologii wideo & audio
    [/QUOTE]
    But usually you can use Xvid instead DivX (can even use ffdshow VfW).[/QUOTE]
    ... and then will I be able to play Xvid and ffdshow compressed movie (VfW) in a standard stand alone DVD player?
  10. Originally Posted by al2502 View Post
    Majority of standalone DVD/DivX players simply supports MPEG-4 ASP wideo with FourCC DX50, DIVX and XVID in AVI container.
    Even if standalone DVD/DivX player does not support the XVID FourCC code (it's rather rare), you can always change code to DX50 (used AVI FourCC Code Changer for example).
    In ffdshow Video Codec configuration, you can choose the encoder (MPEG-4/libavcodec or Xvid ...) and the FourCC code (DX50, DIVX, XVID, ...).
  11. Member netmask56's Avatar
    If you read the requirements as listed on their website http://www.squared5.com/svideo/mpeg-streamclip-win.html you need to either buy the the Quicktime MPEG2 decoder for Quicktime OR install QuickTime Alternative version 1.81 and not more recent versions only this one.
    http://www.filehippo.com/download_quicktime_alternative/?2615
    Apple QuickTime 7 is the official distribution of QuickTime. This free installer is recommended, however it is a very large file (more than 20 MB without iTunes) and it does not include MPEG-2 decoding (you have to buy the MPEG-2 playback component separately from Apple, for $19.99).
    TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung ES8000 65" LED TV ~ Windows 7 & MAC G4
  12. netmask56, please... al2502 would like to convert AVI file with MS MPEG-4 video - not MPEG-2.
  13. I am having the same issue with no video when I use mpeg stream to convert my avi to a dv file. But I am trying to put the video into final Cut Pro so I can do some editing to it. It is also a full length movie, but only converts about the first 3:30 of it, so if anyone knows why this happens please let me know how to fix it . Could someone please help me out on how I should fix this? Here are the specs of the video:
    Video
    ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (MPEG) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 58mn Bit rate : 1 988 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.090 Stream size : 1.65 GiB (81%) Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 2000 Duration : 1h 58mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 380 MiB (18%) Alignment : Aligned on interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 512 ms
