version 224 has been fine for lots of conversions but now 226 gives me very bad looking output. I even tried converting the same small clip with 224 and 226. The output of both was same size and same bitrate but the output of 226 looks like it has a very low bitrate. I tried letting avstodvd choose the encoder for me and I tried forcing the encoder HCENC 1-pass and HCENC 2-pass (I never use QUENC) but the output always looks horrible. I'm not really looking for a fix as I can just use 224, I just want to know if this is a known issue or not? If so i'll just wait for the next version.
Actually now both 224 and 226 are doing the same thing, really bad output suddenly. I never tried 225. I am first going to delete all my avstodvd folders (I use the no_install versions) then redownload. I will also clean any avstodvd entries out of my registry. I'll reinstall avisynth too just for a goof. If that doesn't fix my issue I will convert my test clips then post the logs here. Thanks.
Ok so I did what I put in post #3 without going into the registry and it did not work initially. I then repeated everything in post #3 as well as deleted the reg key HKEY_CLASSES_ROOT\VirtualStore\Machine\Software\AVSTODVD. Everything is back to normal now.
AVStoDVD help pls!
By merovingio in forum Video ConversionReplies: 1Last Post: 15th Oct 2011, 17:25 -
DVD Flick & AVStoDVD issues ...
By iCaptainChaos in forum Video ConversionReplies: 2Last Post: 9th Aug 2011, 10:19 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 07:29 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 05:01
