  1. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    I just have a simple question .....
    Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9 as an UPGRADE ? Some sites say NO however , Sony site seems to say yes ? Anyone ?
    http://www.sonycreativesoftware.com/upgrade/vegaspro
    Anyway, good to be back....
    The answer is always easy for the person who has it....
    Apr 2004
    Miskatonic U
    Why not put your serial number in and see if it OKs it ?
    Read my blog here.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Next time use a title with more description,i have changed it this time for you.
  4. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Okay, not sure what you mean put my serial number in ..wouldn't I have to BUY it first ? And is it doesnt work ..I am hosed ? What am I missing and THANK you for fixing the subject line....
    canada
    The link you gave to the site has the qualifying serial number box you put your number into,thats the one guns1inger mentioned.Dont need to buy it to do that.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Yep, your version 5 serial number. It will tell you if it qualifies for an upgrade
    Read my blog here.
  7. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Duh...never even saw that ...THANK YOU...It works
