VideoHelp.com Forum
    I'm trying to remux a 4 GB avi file but the resulting file has a "preload = 192," according to GSPOT. My divx player does not like this preload setting for some reason and avi files with preload=512 has no issues with my divx player.
    What settings in AVI-MUX do I need to change to make it preload=512?
    VirtualDub: File -> Open Video File, Video -> Direct Stream Copy, Audio -> Interleaving... preload=500, File -> Save as AVI
    Thank you Jagabo.
    I did this exactly as you prescribed, actually with VirtualdubMod, and according to GSpot, the resulting file is show below.
    Container:
    Note: 672 bytes unneeded bytes at end of file
    Multipart OpenDML AVI (3 parts)
    (66987 frames in first part, 86349 frames follow)
    Interleave: 1 vid frame (42 ms), preload=512
    Audio frames: Split across interleaves
    User Data / Metadata:
    [ISFT] VirtualDubMod 1.5.10.2 (build 2542/release)
    [JUNK] VirtualDubMod build 2542/release
    [USER] XviD0050
    Therefore, my initial problem is solved but the solution presented another possible concern of which I am not sure if I should be worried (should I?) so I have bolded what could be a problem for standalone playback issue.
    If this is problematic, what could I do to fix this?
    I haven't seen VirtualDub or VirtualDubMod do that before but if the junk at the end of the video isn't causing problems I wouldn't worry about it.
  1. .srt Subtitle in "not DVD" File like mp4, mov or avi
    By oldMac in forum ffmpegX general discussion
    Last Post: 8th Apr 2010, 18:12
  2. "stretching" or "cramming" aspect ratio when I convert .avi to MP4
    By Agent Bauer in forum ffmpegX general discussion
    Last Post: 21st Mar 2010, 10:30
  3. Question why AVI-Mux GUI cuts down file size
    By jimdagys in forum Editing
    Last Post: 16th Apr 2009, 03:18
  4. Replies: 1
    Last Post: 24th Sep 2008, 11:47
  5. h264 + ac3... .mkv mux in synch, .avi mux out of synch...
    By homerpez in forum Video Conversion
    Last Post: 5th May 2007, 05:42
