VideoHelp.com Forum
  1. I need a program who extract DTS and AC3 signals from a mkv.
    I want the 6 audio channels separated.
    please help me!!!
    Thanks!!!
    MkvExtract/MKVExtractGUI to get the audio out of the MKV file.
    I don't know what the current thinking is on demuxing these back to mono wavs. Eacto is usually used for most other manipulations, but only appears to do mono wav output from PCM sources.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. I trie with that. But that program ony extraxt all the audio (the 6 channels into 1)
    Y need the six separated audio channels.
    thanks anyway!!!
    I use Tranzcode for this to be done.
    Each channel to a separate mono wave. Itīs freeware.
    you can extract 6 mono wavs from most 6 channel sources with eac3to ; you have to specify "wavs" not "wav"
    if you don't feel like using command line, here is a mini guide for the GUI
    http://forum.videohelp.com/threads/3...-separate-WAVs
    eac3to can read from directly from mkv (not necessary to demux), the only difference in those screenshots is that you have to select the audio track number (in the 2nd tab, to the left of the red "5" ; the audio will usually be track #2
  6. Nobuddy! thanks for the tranzcode. Works great with .dts
    I need now resolve the AC3 issue.
    poisondeathray, thanks too. But your program is too difficult to me.
    thanks a lot people!!
  1. convert DTS from MKV to AC3
    By cajmere in forum Audio
    Last Post: 9th Nov 2011, 21:04
  2. Replies: 5
    Last Post: 3rd Jun 2011, 08:17
  3. MKV - DTS to AC3 nightmare
    By aaron1104 in forum Video Conversion
    Last Post: 11th Oct 2009, 03:17
  4. Replies: 1
    Last Post: 8th Sep 2008, 17:42
  5. Replies: 1
    Last Post: 24th Feb 2008, 02:26
