VideoHelp.com Forum
    When streaming the file to my Xbox I actually could hear and see the video fine, but it was extremely choppy. This particular video is 1080i. What format can I convert it to (WITHOUT quality loss) and play smoothly on the Xbox 360??
    open vlc and use that to remux the video to mp4 this will not convert the video
  3. Member yoda313's Avatar
    Better yet use ps3mediaserver or tversity to stream. They will transcode it.
    Also are you streaming it wirelessly or wired? If you are wireless you could be experiencing buffering issues. If you have a non slim xbox 360 you can get a wireless n adapter now if you have a wireless n router. That should improve your performance. However for maximum consistency you should look into streaming wired over your lan.
    How is transcoding the video "better" than using the original streams?
    First and foremost check your nework, if you are using B/G wireless then that is likely to be the cause of the problem.
  5. Member yoda313's Avatar
    Better may be the wrong term to use in this instance.
    Quicker and more efficient would certainly apply.
  1. Replies: 0
    Last Post: 13th Sep 2011, 02:39
  2. Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
    By ycrazyy in forum Newbie / General discussions
    Last Post: 14th Jan 2010, 15:25
  3. i need this to stream on xbox 360
    By carlos28355 in forum Video Conversion
    Last Post: 1st Jul 2009, 19:18
  4. Stream .iso to my Xbox 360
    By nfl2k2 in forum Media Center PC / MediaCenters
    Last Post: 21st Oct 2008, 17:43
  5. Stream MKV to Xbox 360
    By spork985 in forum Media Center PC / MediaCenters
    Last Post: 21st Jun 2008, 06:35
