I'm on Windows 7 64-bit and installed the 64-bit version. I've also enabled DVXA.
During playback, CPU never goes about 10%. However, I still get some random pixelation.
Am I missing something?
This is an i3 laptop with 4GB of DDR3 with a discreet Nvidia 300M graphic card.
Results 1 to 11 of 11
Thread: 1080p MKV playback using MPCHC
Have you tried different video output directshow ? Under options->playback->output.
How does it work if disable dxva? Also pixeletion?
What mpchc version? Latest official build or beta?
Maybe your files are corrupt. Maybe they aren't DXVA compliant.
Version: 1.3.1249.0
I'm only running DVXA output filters where possible, having unchecked the similar ffmpeg option.
The video is MPEG4 ISO and AC3 audio.
It says "Playing DVXA" in the bottom left corner.
You might also try disabling MPCHC's internal MKV reader/splitter filter.
Your file probably just uses h.264 features that aren't supported by DXVA.
The 1080p file is an old BD rip and the smaller file is 720p TV show from a few weeks ago.
Both have the same codecs, weirdly enough.
I tried in DVXA and both files either had pixelation or didn't play (TV Show).
Without DVXA, both files played fine, with no pixelation.
Very odd. My graphic card is a mobile one, but recent enough (310M from nVidia).
1080p MKV Choppy Playback - Solved!
By sdbyrd in forum Software PlayingReplies: 4Last Post: 11th Oct 2011, 03:35 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
Stuttering playback of 720p/1080p mkv when enabling subtitles
By skr@icelab.dk in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2010, 15:09 -
1080P MKV playback issue
By nekromantik in forum Software PlayingReplies: 15Last Post: 14th Jan 2010, 16:40 -
Slow MKV 1080p Playback!
By The_WRATH in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 13:50
