Folks-
Total noob here, but have spent many hours trying to find a solution. We're at urgent level at this point. Need some MAC help here. If you know of a better forum for MAC users, please advise.
QUICK DESCRIPTION
I still can't see audio in VOB2MPG's exported mpg file when I try to edit it in Final Cut Pro.
LONG DESCRIPTION
Our workflow is MAC. We have 500GB of .vob video content (both PAL & NTSC) that needs to be edited in Final Cut Pro. I have tried numerous options to get the content ready to edit. I've tried several options in ffmpegX (mux and demux) without success, though it's highly likely I'm not doing something right. So finally I decided to use this software I see many PC users mentioning: vob2mpg. I install it on a PC and appears to work fine. Exports mpg file. It plays fine on PC and in VLC player on MAC.Then I try to import into Final Cut Pro.
All the content, whether .vob or .mpg still does not contain audio in Final Cut.
MAC SPECS:
Quad core iMac 27"
Snow Leopard
Final Cut Pro Studio 7
Installed Perian tools
Installed ffmpegX (not that it matters)
PC SPECS:
It's old. But the video plays fine when exported.
Installed VOB2MPG version 3 (not pro...yet)
Any help would be much appreciated.
-paul
It appears that I'm supposed to add yet another stage to this process: MPEG Streamclip. However, I can't find the support files in the system folder where they should be:
http://www.squared5.com/svideo/mpeg-streamclip-mac.html
In case someone else is struggling with this, I posted an updated issue here:
http://discussions.apple.com/thread....4201&stqc=true
If anyone else has a solution, please do chime in.
Not sure about the MAC related issues - but on the PC: no sound is usually down to the fact that you don't have an AC3 directshow filter installed. Again for the PC, the solution is to install AC3Filter.
canon G1000/G1500 G10Hi to Final cut on Mac book Pro (15 inch)
By laurie in forum MacReplies: 7Last Post: 20th Feb 2011, 13:53 -
Final Cut Pro, keeps glitching, then muting audio
By Huntr777 in forum MacReplies: 5Last Post: 18th Jul 2010, 03:08 -
How to convert srt/sub/ssa to SON/SCR for "Final Cut Pro" on Mac
By mriddler in forum SubtitleReplies: 18Last Post: 3rd Nov 2009, 07:08 -
Final Cut Pro imports .MPG's with no audio.
By Benhermies in forum MacReplies: 2Last Post: 20th Sep 2009, 16:09 -
MPEG 2 to Final Cut Pro - No Audio
By Huntr777 in forum MacReplies: 5Last Post: 5th Jul 2009, 19:14
Statistics
Newest guides
Latest tool updates
New media comments
