VideoHelp.com Forum
    Hi ,
    i bought this model, Philips DVDR5520 with Digital TV Tuner
    the problem is that the digital channels in my country are mpeg4 and this model supports mpeg2
    i can find the digital channels through scan but i can only listen to them without any picture
    does anybody know if there is a firmware upgrade or hack so ican receive mpeg4 channels
    or its a hardware issue that i will never manage to solve
    thx!
  2. I have same recorder, and if you could get it to work reliably its not too bad (a bit slow). Your question however is not solvable. The Digital tuner in there actually probably? supports dvbt1, which is the transmission method, rather than dvbt2 which is a newer higher efficiency method (used to xmit HD/freeview/UK/mpeg4). Actually in your country maybe they broadcast std def in mpeg4? I doubt whether this m/c can be hacked tho as the tuners inside are generic suitable for the widest range of countries. Silly to buy it without checking first ..
    UK present mpeg2 broadcast using 64mod? Dvbt std def.
    Future mpeg4 broadcast using xxxxxx? dvbt2 High Def. (A world first)
    Complete Digital switchover 2012 .. increased Signal strength all round.
    The electronic components of the power part adopted a lot of Rubycons.
    I suppose you want any dvd to be playable in other makes of players, right?
    I have a feeling rabidDog is right, unless you know a super tech familiar with that brand...I kinda doubt it.
    Beware that I have a similar model, and it is having issues keeping the current date in memory, and the digital tuner overheats and goes blank!!! so, I'm not too pleased with the philips brand
  1. Sony BDP-S370: Firmware upgrade to 567 and region free hack
    By Nosh3 in forum DVD & Blu-ray Players
    Last Post: 19th Jan 2011, 07:57
  2. Philips BDP7500 firmware hack
    By Sylph in forum DVD & Blu-ray Players
    Last Post: 28th Dec 2010, 14:05
  3. PHILIPS DVP642... how do I upgrade the firmware?
    By mummer43 in forum DVD & Blu-ray Players
    Last Post: 14th Jan 2009, 18:45
  4. Philips DVP5900 DVD player firmware upgrade for HDMI - need help
    By s_poisk in forum DVD & Blu-ray Players
    Last Post: 24th Oct 2007, 08:41
  5. Philips DVP5960 dies during firmware upgrade. HELP!!!
    By croft in forum DVD & Blu-ray Players
    Last Post: 15th Jun 2007, 11:21
