I searched but did not find.......
I am using a stand alone DVD recorder to record TV shows directly to DVD-R. I then rip the VIDEO_TS folder from the recorded DVD's to my hard drive for storage/editing/burning later. My question is : If I use DVD-RW to record the shows, leave the disc UN-finalized, can I still rip the VIDEO_TS folder to my HD then just erase the DVD-RW and start again with the next show re-using the same RW disc over and over?
What process does the stand alone do when you tell it to finalize a recording?
check out my videos:
http://www.youtube.com/user/DirtBikeMikeHubbard
The reason you finalize is so that other dvd players can read the disc,if you can rip the dvdrw without finalizing then there's no reason to finalize since you're going to erase it anyways.My burner can rip unfinalized dvdrw but some others cant,just gotta try.
Finalizing a dvd closes the track(s) and no more burning can be done.Ben Johnson-I didnt take any stereos!
Even IF the RW needed to be finalized to be read by your PC drive, it would not be permanently finalized, you would just use it again and record over whatever was on it.
Originally a member since 2001, LONG LIVE TARAN's!!!
Thankx tonz fellas....that's exactly what I was looking for.
Finalize DVD-R, is this possible?
By chiyoaiki in forum DVD & Blu-ray RecordersReplies: 30Last Post: 11th Mar 2012, 15:17 -
finalize DVD
By bobaumichedu in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2011, 13:59 -
Can't finalize BD-RE?
By DGenerateKane in forum MediaReplies: 0Last Post: 23rd Sep 2009, 18:45 -
Disk Finalize
By arobertson1 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 4th Sep 2008, 18:28 -
finalize Help
By whittyscosie in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 13:27
Statistics
Newest guides
Latest tool updates
New media comments
