I'm ripping my dvd collection to my computer.... then converting them and placing on an external hard drive for play on my xbox 360.No problems using dvdfab and handbreak.No problem until I tried the dvd-r's that were recorded on my samsung dvd recorder...The dvdrw disc's worked fine but the computer doesnt even see the files on the dvd-r's. supposedly the Dell inspiron's drive supports dvd-r's. I am what you would call " very new" to this so any Ideas would be appreciated.....
70 movies and counting......All ready to play on the xbox
Results 1 to 12 of 12
a very simple solution would be to get an external dvd writer...usb...u shouldnt have any issues then
how old is the pc your on?
It's a new dell inspiron 1545. I'm ripping and converting to a folder and simply dragging and droping to the ext hard drive Then take it to the xbox .vidieo's ready to play. So you think the Drive (or windows?) doesnt recognize the dvd-r's? As I say,the dvdrw's are no problem.and they were recorded with the same recorder.
sorry if I'm ignorant about this...as i said ,I'm new.
You may need to finalize the DVD-Rs. Check your recorder's manual.
Hadn't thought of that.....I guess it doesnt automatically do that upon ejection??
if its new then its should see those dvd-r's...i cant see why they wouldnt
so basically your "dvd-r" discs arent being seen at all thru your dvd drive? open up "my Computer" and then put the disc again and see if it recognizes it...if you've had these discs for a long time and you've played them b4 i'm sure they've been finalized..if they can be seen then try ripping them with dvd decrypter to your ext. HD
They have only been played in the player that recorded them to this point....and over and over at that.but for some reason the computer see's the disc as empty.the disc shows up but no files available.....will investigate the "finalization" thing. Anything else to try???
Most standalone DVD do not finalize upon ejection of the disc. Finalization "locks" the disc so that no more information can be written or deleted from it. This procedure is usually a separate step.Originally Posted by nodollas
Thanks guys......will see where this goes
Well That seemed to do it . The discs werent finalized. now they rip like a dream only problem now is Handbrake Sometimes get audio out of sync........always something.
im not sure if your ripping your DVDs to AVI files but if so
prior to burning them
you can fix the audio out of sync problem easy using virtualdub
Storing DVD's on an external hard drive
By avz10 in forum DVD RippingReplies: 6Last Post: 22nd Jan 2010, 10:47 -
DVD player with external Hard drive
By dbnite-wp in forum DVD & Blu-ray PlayersReplies: 14Last Post: 23rd Sep 2009, 01:46 -
Want to copy a DVD to external Hard Drive
By bwm258 in forum DVD RippingReplies: 9Last Post: 29th Jul 2009, 00:22 -
External Hard Drive to DVD Player through TV
By illpeeonu in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Feb 2009, 12:02 -
Ripping to External hard drive
By mercuryguy in forum MacReplies: 5Last Post: 25th Jan 2008, 13:10
