VideoHelp.com Forum
    Hello,
    I have a couple of naive questions:
    • - Has anyone heard of a firmware update that would allow the Lacinema Classic to be able to play the video files that the Lacinema Classic HD can play (such as mkv / h.264 files)?
      - Hard drive-wise, I only know from the manual that the drive cannot be formatted NTFS; only in FAT32. Is there an issue with defragmenting? (I assume not, but thought I would ask in case someone else had a bad experience with such.)
    Thanks in advance!
    All windows files systems are prone to fragmentation. The more you delete and write to the disk, the more likely you are to suffer from it. So once a month or so, connect it to your PC, defrag it, and you will be fine. If you aren't deleting and writing too frequently, you might only need to defrag it every three or six months.
    As to the firmware update : unlikely. There is a good chance the classic simply doesn't have the processing grunt to play HD material. Does it even have the right outputs ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    That sound good to me - I will go ahead and defragment away, thanks!
    Hmmm...the Classic does have HDMI out and it upconverts to 1080p if you select it in the options (works well today with my TV), so I assume it might have the ability to play HD material...just was not sure if someone knew of a way to provide such...
    There is a huge difference between being able to upconvert SD material to 1080, and being able to actually play 1080. Not the same thing at all.
    Understood - perhaps I am stuck then. Thanks for your replies!
  1. Lacie lacinema classic hd won't upgrade firmware
    By GadgetLover in forum Media Center PC / MediaCenters
    Last Post: 28th Jan 2012, 20:55
  2. LaCie Lacinema Classic 1TB won't play video
    By mike_cd1982 in forum Newbie / General discussions
    Last Post: 13th Jan 2012, 12:47
  3. How do I reset video settings on my Lacie LaCinema Classic drive???
    By neilharris76 in forum Newbie / General discussions
    Last Post: 2nd Sep 2011, 18:25
  4. Problems with Lacie Lacinema Classic
    By otinimeg in forum Newbie / General discussions
    Last Post: 12th Mar 2011, 18:44
  5. Lacie LACinema Classic HD - 1T
    By AN11211 in forum Newbie / General discussions
    Last Post: 22nd Feb 2010, 12:25
