I was thinking maybe use old computer with a firewire to capture from my videocamera but does it use the computer soundcard?
Or can I use it to recording sound from a mic at the same time?
No, it doesn't. The audio is part of the data being transferred.
You can record audio at the same time, although it will be to a separate file and depending on the software used, drive being recorded to etc, could cause dropped frames and other issues with the capture.
thanks.
You can use Graph Edit to replace the audio stream in the DV with that from the sound card. Some other apps can do it (Window Media Encoder, VLC) but the captured format may not be DV.
Well I was thinking about maybe use firewire to capture a videocamera and use the computer soundcard to capture a mix table
No sound in WME with USB capture card
By bomb jack in forum CapturingReplies: 2Last Post: 25th Feb 2011, 03:40 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum CapturingReplies: 8Last Post: 16th Mar 2008, 08:55 -
Is a HDMI capture card or firewire better for transferring dvr recordings?
By yoda313 in forum CapturingReplies: 0Last Post: 9th Dec 2007, 13:42
