Anyone know of a utility or method of extracting the chapter times from a bin/cue that has been mastered with chapter entrypoints? Other than just playing it and writing down the times, that is![]()
I sometimes have to extract the MPG from a bin/cue and either remux it or normalize the audio, but I hate to lose the original DVD chapter info if I can help it.
Thanks.
Definitely!
Use VCDXRIP, a tool included in VCDImager. This proggy will extract all the media files and pbc information into MPEG files and an XML descriptor of the VCD.
Do the relevant editing of the XML file (e.g., adding in new features) or editing of the MPEG files (e.g., switching menu screens) and then you can rebuild all this back into a CUE/BIN image of a VCD with VCDXBUILD.
These are both command line tools but VCD Easy (which you can download from this site) is a GUI for both these proggies (among other things).
Regards.Michael Tam
w: Morsels of Evidence
Ah, now I see. I had tried this before with VCDEasy and never noticed that you have to actually rip the MPG stream (not just the XML) to get the chapter entrypoints.
Works like a charm. Thanks very much
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
Statistics
Newest guides
Latest tool updates
New media comments
