I am running vista 64bit.
I, like many ppl, are converting my dvd collection to mpg using clone dvd to get the vob's and vob2mpg to get the mpg.
I have no problems getting the vobs off the disk but have some problems with the vob2mpg software.
I am using the free version and I was running the .0131 I keep getting "finished processing" before anything started... but it was only on a few dvd's. i upgraded to the latest version .0520 and i am having the same problem with the "finished processing" and now also getting "this operation is not permitted in the current domain"
I have read a few posts on the"finished processing" but they always get off topic with no resolution.
please help.
Tim
Results 1 to 9 of 9
Thread: vob2mpg problems
Living in a 3D world, Playing in a 3D world
Can you post your log file please?
Do I have to run something to get that or can I find it in a folder.
Thanks.Living in a 3D world, Playing in a 3D world
Click 'Help' button, then choose 'Open Logs Folder'...
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
here is the log file: FYI... I set the program to VOBSET Mode and it worked. I dont understand what dif. that makes...
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title:
Version: 3.0.0520
Executable: C:\Program Files (x86)\BadgerIT\VOB2MPG v3\VOB2MPG.exe
Executable size: 584 KB
Executable size in bytes: 598528
Executable CreationTime: 1/19/2010 10:51:06 PM
Executable LastWriteTime: 1/19/2010 10:51:06 PM
Executable LastAccessTime: 1/24/2010 12:51:23 PM
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 20.4 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 66.1 GB
********************* END OF SYSTEM INFORMATION ********************
/v="E:\My Movies\Fast and the Furious, The\VIDEO_TS" /t=1 /o="C:\Users\NewTekBuzz\Videos\New Folder\Title_1.mpg"
08:18:36
Extracting from Title: 1
08:18:36 vPaths: E:\My Movies\Fast and the Furious, The\VIDEO_TS\VTS_01_1.VOB,E:\My Movies\Fast and the Furious, The\VIDEO_TS\VTS_01_2.VOB,E:\My Movies\Fast and the Furious, The\VIDEO_TS\VTS_01_3.VOB,E:\My Movies\Fast and the Furious, The\VIDEO_TS\VTS_01_4.VOB,E:\My Movies\Fast and the Furious, The\VIDEO_TS\VTS_01_5.VOB,Living in a 3D world, Playing in a 3D world
I think it is because it doesn't like commas in the file path. Can you change the folder name so that it doesn't contain any?
ChrissyBoy,
I will give that a try in the next couple of days. I will report back soon.
Thanks for the help
TimLiving in a 3D world, Playing in a 3D world
Running a new purchase/install of vob2mpg pro. It will, with prior backups of copied dvds to a mpeg file no problem, but if i try with a factory dvd- iget sound but no video- what am i doing wrong or what extra software is needed?
vob2mpg
By peebee44 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Dec 2011, 15:02 -
VOB2MPG not working
By les972 in forum Newbie / General discussionsReplies: 6Last Post: 19th May 2010, 19:05 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Where to get vob2mpg v2
By freq in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Nov 2009, 11:47 -
vob2mpg subs problems
By bountylord in forum SubtitleReplies: 8Last Post: 24th Feb 2008, 03:49
