I'm trying to convert a VOB file in WideScreen to DV to be able to edit it changing the chapters (they were set random).
I'm using ffmpegX (for MAC) but can't get the correct display ratio. Can you tell me the right settings, or other software I can use?
I know I can demux the file and then edit it in DVDSP (from Final Cut) but I don't have that expensive software so I will have to reencode to DV, to edit in ImovieHD.
Why convert to DV and then back to DVD? A waste of time and quality. Just demux, create the chapters, and remux.
1. Demux (PGCDemux)
2. Edit the chapters (a Celltimes.txt with the frame numbers where you want to set the chapter points). .
3. Remux, adding in your edited Celltimes.txt (Muxman)
4. Replace the old one with the new one with better chapters using the 'Replace' button of VobBlanker. The total number of chapters should be less than or the same as the original number. If greater, then you had best do the replacing in PGCEdit (File->Replace VTST Titles).
I have no idea which programs might not work on a MAC, but you're going about this entirely the wrong way if all you want to do is change the chapter points. If you can't do it as I described, surely there are ways even a MAC user can demux and reauthor without reencoding the video twice.
AVC Frame size and video display
By soonerk in forum Newbie / General discussionsReplies: 1Last Post: 30th Apr 2012, 05:33 -
what display size should I use in TV card settings
By jimdagys in forum CapturingReplies: 1Last Post: 8th Apr 2008, 20:51 -
Fine-tuning display size on remote plasma
By Fred429 in forum Media Center PC / MediaCentersReplies: 0Last Post: 29th Mar 2008, 02:46 -
Display size in Windows Movie Maker H E L P !
By redwolfhopw in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2007, 19:25 -
DVD display size issue
By tanshul22 in forum Software PlayingReplies: 1Last Post: 28th Nov 2007, 19:13
Statistics
Newest guides
Latest tool updates
New media comments
