I'm trying to burn a movie into a DVD but it doesn't come with the subtitles. I downloaded the .srt file for the movie but I can't find any software that allows you to burn a movie with subtitles selection into the DVD just like the DVDs we buy.
Any suggestions of that software?
PS: I don't want software that needs us to add the subtitle word by word into the movie since I already have the .srt file. And I don't mind paying for that software as long as it suites my needs.
Results 1 to 10 of 10
Thread: Burning movies with subtitles?
What format is the movie ?
If it is an avi/mkv type file then AVStoDVD is free and can add srt subs.
ConvertXtoDVD is not free and can also do it.
If you already have a DVD and just want to add subs it becomes more complicated.
If you just want to add subs to an already created DVD, then Baldrick has a guide with 2 different methods of doing it:
http://forum.videohelp.com/topic338721.html
GfDOriginally Posted by legenderycity
http://download.videohelp.com/gfd/He...html#Subtitles
I just downloaded the convert x to dvd but I have a problem. The output resolution of the video is only 720x576 when the original resolution is 1920x1080. Any ways to keep the original resolution.
PS:I tried changing the 'DVD Specification' settings but it still doesn't work.
If there is no other way, then is there any DVD burning software that allows you to burn DVD along with subtitles?
No. If you're making DVDs, then it has to be 720x576 (with some other standard-def resolutions allowed). You can't have a DVD and 1920x1080 resolution.Any ways to keep the original resolution.
There are plenty. And they'll all make it 720x576.If there is no other way, then is there any DVD burning software that allows you to burn DVD along with subtitles
Is that so? Then can you tell me one of those DVD burning software which can burn DVDs with subtitles?
DVD Flick, AVS2DVD, FAVC, ConvertXToDVD, AVI2DVD, etc., etc.
legenderycity - You'd really be better off using some kind of media player like one of the Western Digital models that supports high def video and SRT subtitles rather than trying to do conversion to DVD, especially if you think you are going to be watching a lot of high def videos in the future. A Western Digital HD player or similar device should play your video and subtitles without conversion.
Where to find the best subtitles for movies
By cyberlion in forum SubtitleReplies: 3Last Post: 24th Jul 2010, 12:05 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
how do I join several movies and add subtitles?
By dannoura in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2008, 16:17 -
finding forced subtitles for some movies
By hellfire662 in forum SubtitleReplies: 1Last Post: 16th Jan 2008, 15:11 -
Burning Divx movies with subtitles?
By Hank Kinsley in forum SubtitleReplies: 5Last Post: 17th Jul 2007, 11:33
