    Hi guys! I'm sure I'm not the one that have asked this question but I really need to find an answer since I've been looking around and tried 4-5 programs and still couldn't do what I intended.
    In short - I have two .avi files with integrated subs in english, I want to edit them and translate them in my language and keep them integrated, just changed. Simple as that.
    Is it possible ?
    Thanks in advance!
  2. Member midders's Avatar
    What do you mean by integrated? If the subtitles are a separate stream embedded in the avi file, then you can extract this and modify it as required. If the subtitles are hard-coded (i.e. part of the video stream) then you're out of luck. If you're not sure which is the case, then use MediaInfo and post the output here for an explanation.
    Slainte
    midders
  3. With avi/divx there's also the possibility of selectable subs as added by programs like AviAddXSub. According to the author of that utility, once they are in, there's no way to demux them. At least know way that he knows.
    http://www.FavesSoft.com
    "I don't want to belong to any club that would have me as a member."
    - Groucho Marx
    I am a hobbiest when it comes to adobe after effects, but it may be possible to rotoscope out the subtitles if they are embedded possibly using mocha for after effects, however it'd be less time consuming to create an avi file from another and use subtitle workshop.
  1. Editing Embedded Sub
    By ill_kuma in forum Subtitle
    Last Post: 19th Feb 2009, 15:15
  2. subtitles embedded within mp4 container
    By derrickec in forum Mac
    Last Post: 10th Oct 2006, 19:33
  3. Editting embedded subtitles [in MKV]
    By Serphium in forum Editing
    Last Post: 5th Apr 2005, 22:59
  4. embedded subtitles in ogm file
    By punkface in forum Mac
    Last Post: 5th Jul 2004, 05:46
  5. Permanently embedded subtitles...
    By firetoad in forum DVD Ripping
    Last Post: 7th Jan 2003, 11:31
About   Advertise   Forum   RSS Feeds   Statistics   Tools
