VideoHelp.com Forum
    Hi all, I downloaded some clips that are in mp4 format and I used TMPGEnc 4.0 Xpress to convert it to dvd compatible mpg. However the resulting clip has a 'herky-jerky' look to it when played on my DVD player. So I used Mediainfo to find the properties of the mp4 clip and it showed the clip as being 29.00 fps. I guess when it got re-encoded, it ended up being done at 29.97 fps...which might explain the lack of 'smooth' video playback. My question...what is the best way to convert a 29fps clip to DVD so that the video plays 'smoothly'. Should I stick with 4.0 Xpress and change some settings? Use another encoding software? I'm a relative newbie to video encoding/conversion so I'm not familiar with some of the features of these programs.
    Thanks.
  2. Member Soopafresh's Avatar
    29.0 fps is weird. Really weird.
    Try convertxtodvd
    "Quality is cool, but don't forget... Content is King!"
    Was it Variable Frame Rate ? (VFR) ?
  1. MP4 w/ AAC ---> MP4 w/Compatible Audio
    By NotSoEasy in forum Newbie / General discussions
    Last Post: 26th Aug 2011, 15:41
  2. how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
    By redout66 in forum Newbie / General discussions
    Last Post: 14th Sep 2010, 04:53
  3. MP4 29.97 fps to AVI 25 Fps
    By videopetur in forum Video Conversion
    Last Post: 20th Jan 2009, 06:37
  4. Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
    By bananasontoast in forum ffmpegX general discussion
    Last Post: 3rd Jan 2009, 09:15
  5. DVD Shrink + ??? = Zune-compatible .MP4/.WMV?
    By BlueOlive in forum Newbie / General discussions
    Last Post: 23rd Sep 2008, 17:25
