VideoHelp.com Forum
  1. I still cannot solve te problem.
    I installed the latest Haali but to no effect.
    How should I configure the settings in MPC HC??
    Is it possible to play mt2s file in PowerDVD 9 and to be able to choose any audio or subtitle streams?
    I have tried to play this file on PowerDVD 9 but I can only hear some Czech audio stream.
    The options to choose audio or subtitles are disabled.
    Please help
    WHy do you hijack topics? I'm splitting you to a new topic.
    Tried vlc or smplayer?
  4. Sorry for hijacking the topic.
    Recently, I came across a post in which you wrote some very helpful advice about a similar issue.
    However, I cannot find it on the board.
    I would rather firstly make sure if MPC HC can play the file. You wrote in one of the topics some tips on how to configure MPC HC to play mt2s with bulit in audio streams.
    Many thanks in advance
  1. What to use to play .TPO extension ?
    By drwho in forum Software Playing
    Last Post: 11th Dec 2008, 22:48
  2. Replies: 7
    Last Post: 22nd Sep 2008, 15:44
  3. what type of file extension is a movie downloaded using BitTorrent?
    By geek2330 in forum Newbie / General discussions
    Last Post: 13th Dec 2007, 20:15
  4. how to play files with extension mod and moi
    By greendesert in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 14th May 2007, 06:07
