VideoHelp.com Forum
    Hey,
    I've got several .mkv video files I want to author a DVD of. So far I've managed to import them into Adobe Premiere through AVIsynth, Haali Matroska and FFDShow.
    But I just checked the video files and they're all NTSC, and the DVD (I'll author with Encore) will need to be in PAL. I take it this can't be a good thing? At what stage and how should I make this conversion?
    Thanks?
    P.S.
    When choosing the sequencing preset in Premiere for the project, should I select NTSC or PAL? Seeing as the files are in NTSC, but will need to be in PAL?
  2. Member hech54's Avatar
    Australia is getting MUCH better at being able to play NTSC material on their equipment. And since you won't have a region code to worry about....I'd try NTSC first.
    Give AVStoDVD a try.
    It generates AVS script automatically and transcodes the streams for you.
    Geppo
  4. Member AlanHK's Avatar
    Why does it "need to be in PAL"?
    As Mr Hech so perceptively pointed out:
    But if you really want to, this works for me, speeding up 23.976 fps (after IVTC) to 25 fps, resampling the audio:
    ...Source(...)
    #IVTC if necessary
    #Telecide()
    #Decimate(5)
    #Convert to PAL 25 fps, 48000 Hz
    Nfr_num = 25
    Nfr_den = 1
    Ar = 48000
    ResampleAudio(Ar*FramerateNumerator()*Nfr_den, FramerateDenominator()*Nfr_num)
    AssumeSampleRate(Ar)
    AssumeFPS(Nfr_num, Nfr_den, False)
    LanczosResize(720,576)
  5. Member hech54's Avatar
    Originally Posted by AlanHK
    If compatibility with Australian hardware, NTSC is not a problem, in my experience.
    Echo echo echo echo echo echo
  6. Member AlanHK's Avatar
    I'm sorry, do you have a copyright on that statement?
    I thought since I happen to BE an Australian, my actual personal experience might be relevant.
    How silly of me to think that anyone would care about what I thought.
    Tell you what, I'll edit my post, just to make sure everyone knows that "you said it first".
  7. Member hech54's Avatar
    Gee I'm sorry. I thought you were from Honk Kong.
  1. PAL to NTSC avi files
    By reptilia82 in forum Video Conversion
    Last Post: 10th May 2010, 07:08
  2. can you convert pal files to ntsc?
    By videodude1966 in forum Newbie / General discussions
    Last Post: 28th Jan 2010, 00:32
  3. Replies: 0
    Last Post: 9th Apr 2009, 21:43
  4. MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
    By ibzomie in forum Newbie / General discussions
    Last Post: 3rd Jan 2009, 15:07
  5. Replies: 3
    Last Post: 25th Aug 2008, 21:05
