Hey,
Out of interest, I was just wondering how AVIsynth, it's Premiere plugin, Haali Matroska Splitter and FFDShow, all work to enable Adobe Premiere to imported .mkv files, and why each is necessary.
I recently used these 4 programs, to do just this, without really understanding what was happening, I'd love to know if anyone out there can explain it?
Thanks.
I don't know any programming, but I know on a very basic level how this works. It's the same as if you used and .avs script ,and done through directshow
Haali Spitter is the splitter/source filter for .mkv, and splits video & audio. You can visualize this with graphstudio for directshow filters
FFDShow is the decoder, and feeds decompressed images out. It may or may not be the audio decoder as well, depending on how you have your system configured, and what the source file type is
The Premiere AVS Import plugin converts the frameserved image through avisynth to RGB so premiere can "understand" it. It works though the CS4 plugin API framework. Adobe released a kit a while back for 3rd party plugin development, but apparently it's very very buggy
You should be able to contact the authors on sourceforge if you want more info on the .avs import plugin
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 17:45 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Need Better System to Run Adobe Premiere CS4
By Funky Monk in forum ComputerReplies: 13Last Post: 16th Oct 2009, 15:36 -
Canon T1i...importing .mov into Premiere CS4?
By callmedpit in forum Newbie / General discussionsReplies: 5Last Post: 21st Aug 2009, 12:28 -
Importing / Editting Edius AVI clips in premiere CS4
By Wael in forum EditingReplies: 2Last Post: 15th Jun 2009, 08:31
Statistics
Newest guides
Latest tool updates
New media comments
