VideoHelp.com Forum
  1. Member devdev's Avatar
    i need to play
    i) a hd file straight from pc and capture onto a blu-ray disc
    ii) an sd avi file straight from pc and capture onto a blu-ray disc
    does anyone know if such a blu ray dvd recorder exists yet?
    and if it it did, would i need to buy a bit of hardware to convert files first?
    philippe
    It would be possible with a graphics card tvout/svideo/composite/hdmi/dvi connected to the recorder.
    But NOT if you mean like from the files directly.
  3. Member devdev's Avatar
    our BlackMagic Intensity Pro card has both HDMI and RGB component
    HD outputs.
    So then presumably if i had a BluRay recorder, all yi'd have to do is hit
    play on the BlackMagic computer and record on the BluRay and that's it?
    im not even sure having said that that theres a recorder with a hdmi input you see
    philippe
  4. Member devdev's Avatar
    are there any blu ray recorders with a hd input?
    philippe
  1. Replies: 31
    Last Post: 1st Feb 2012, 13:39
  2. True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
    By BilboFett in forum Blu-ray Ripping
    Last Post: 27th Feb 2011, 11:29
  3. Panasonic homedeck 3d bluray recorders
    By mazinz in forum DVD & Blu-ray Recorders
    Last Post: 20th Feb 2011, 16:01
  4. How to re-author back to bluray from BDMV bluray structure?
    By eummagic in forum Authoring (Blu-ray)
    Last Post: 1st Dec 2010, 21:14
  5. Replies: 1
    Last Post: 9th Aug 2010, 14:05
