VideoHelp.com Forum
  1. Member logicom's Avatar
    Hello,
    is it possible to associate more audio channels to one video in a live streaming scenario using WMV encoder ?
    I need to be able to encode live 4 languages, and one video, for streaming.
    As you explained here:
    http://www.videohelp.com/forum/archi...s-t314304.html
    it is possible to prepare files in advance with multilanguage support.
    The difference is that i need the same thing but in realtime for live streaming with multilanguage support.
    Please give me some tips.
    Kind Regards.
  2. Member Cornucopia's Avatar
    What I found out:
    1. Standard WME only streams from 1 Live source at a time
    2. Each source ONLY supports 1 video stream, 1 audio stream, and 1 script stream in LIVE BROADCAST STREAMING mode
    3. Multiple instances of WME may be used, but they won't be linked or synced at all, and are meant to be directed toward different targets
    So, unless you find/create a custom encoder (possibly hardware), or - on the off chance that the underlying API supports more, you find/create a custom GUI, you're probably out of luck.
  1. Could you please help me in streaming live TV?
    By mrweb in forum Video Streaming
    Last Post: 25th Sep 2010, 07:47
  2. Streaming Live HD content
    By niceluciano in forum Video Streaming
    Last Post: 29th Oct 2009, 17:03
  3. Streaming Live
    By Black-Logik in forum Video Streaming
    Last Post: 20th Mar 2009, 19:03
  4. Live Streaming
    By futurewebboss in forum Video Streaming
    Last Post: 8th Mar 2009, 19:57
  5. Streaming Live
    By Tucker19 in forum Video Streaming
    Last Post: 25th Nov 2008, 09:00
