VideoHelp.com Forum
    First time I format and then write to a DVD+RW disc (AVCHD using MultiAVCHD), it plays fine. If I then re-write the disc with other material, it will not play. It's happened with both Memorex and now Verbatim discs. Indicates an Invalid format. Any suggestions? Thanks.
    wwaag
  2. I'm a Poll Super Moderator johns0's Avatar
    Check the disc after you do a burn and see if its ok on your computer,might have to do a full erase if the disc doesnt burn proper.
    Ben Johnson-I didnt take any stereos!
    I re-burned another disc on a different computer--same result. Then tried a DVD-RW which worked fine. Guess the Sony does not support DVD+RW's--the owner's manual isn't very clear. Too bad since I just bought a spindle of the +RW's.
    wwaag
  4. I'm a Poll Super Moderator johns0's Avatar
    I have a sony 350 and it plays dvd+rw,did you try a full erase?
    You're right. I did a full erase, re-burned the disc and it worked. Only problem was the 15 min time to do the full erase. Is this normal? I'm using Imgburn. Thanks.
    wwaag
    wwaag
    Did you do a full erase on the disc initially? You can't do "quick erase" unless the disc has been full-erased previously. That's my rule of thumb for all DVD+RWs
  1. Sony BDP-S360 UK
    By BobJoe in forum DVD & Blu-ray Players
    Last Post: 17th Oct 2011, 09:20
  2. Help with SONY BDP-S360
    By leochen in forum DVD & Blu-ray Players
    Last Post: 4th Apr 2011, 12:08
  3. Play files without authoring on my blu-ray player Sony BDP-S360
    By vandaLo in forum DVD & Blu-ray Players
    Last Post: 3rd May 2010, 23:50
  4. Replies: 25
    Last Post: 3rd Mar 2010, 13:18
  5. No CD-Text on Sony BDP-S360?
    By RacerXRed in forum DVD & Blu-ray Players
    Last Post: 2nd Dec 2009, 22:07
