VideoHelp.com Forum
    Does anyone have a list of 5 or 6 popular DVD authoring software that will not re-encode the MPG?
    All I want to do is take a MPG compliant file, add a title menu, create chapters, and then create the DVD VIDEO_TS folder without re-encoding the entire MPG video. I'm not even going to be using transitions.
    I think these will do the smart-encoding:
    -TMPGEnc Authoring Works 4
    -Womble MPEG Video Wizard
    Any others?
  2. Man of Steel freebird73717's Avatar
    gui for dvdauthor (free)
    dvdauthorgui (free)
    dvdlab (not free)
    Also check out the dvdauthoring tools section
    http://www.videohelp.com/tools/sections/authoring-dvd
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    Generally, advanced authoring tools don't re-encode if the MPEG-2 file is DVD compliant and will fit the designated disc size. But oftentimes those software programs will give you the option to re-encode, if there is some need.
    Look at DVD-Lab Pro, GUI for DVDAuthor, DVDIt Pro, or many of the other tools found here: http://www.videohelp.com/tools/sections/authoring-dvd
    EDIT: Oh gee, I didn't see Freebird73717's post. I'm redundant.
  4. Member fritzi93's Avatar
    TMPGEncDVDAuthor used to be popular, but I don't do DVDs much any more, so other than that I dunno. :P
    For cheapskates, there is some freeware which will definitely not re-encode:
    DVDAuthorGUI
    DVDStyler
    and others.
    Most of the members here will use either High-end ($) NLE editing/authoring programs, (the pro and semi-pro members), or they are hobbyists that don't mind doing things manually, which means all the freeware stuff. I'm in the latter group.
    Seriously though, if as you say the file is compliant you should be able to find an option not to re-encode, no matter what the program. Either that or the files are not compliant, will not fit the allotted size, whatever.
    [EDIT] I'm doubly redundant.
    Pull! Bang! Darn!
  1. Help: AVCHD Canon recordings & smart encoding
    By fox86 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Apr 2012, 01:24
  2. Replies: 5
    Last Post: 15th Oct 2009, 16:51
  3. Replies: 1
    Last Post: 17th Nov 2008, 23:53
  4. nero smart encoding
    By m baqar in forum Authoring (DVD)
    Last Post: 27th Mar 2008, 05:13
  5. Overscan + Encoding Programs
    By Unlucky_Owl in forum Video Conversion
    Last Post: 7th Jul 2007, 21:36
