VideoHelp.com Forum
    Hi, I got a great tip on here about ImgBrn and thought I'd give this question a shot. I'm looking for a software that performs reliably able to copy WAV, MP3, etc to my hard drive, covert one format to the other if necessary and burn as good and reliable as Imgbrn. I own Nero 7 and can easily upgrade it but Nero, as I recall, has had it's problems. Is there anything else out there I should consider? Not looking for shareware specifically so cost is not really an issue.
  2. Member hech54's Avatar
    ImgBurn can create either DATA or AUDIO CDs from WAV or MP3 files(ImgBurn will convert the MP3 files to compatible files for AUDIO CD).
    CDex is the easiest CD to WAV, MP3 ripper. Most "rippers" can also convert audio "files" from one format to the other.
    So, use Cdex to copy from original CDs and ImgBurn to burn? I noticed it's freeware too.
  4. Member hech54's Avatar
    That depends on whether you want an audio CD or a data MP3 CD....but ImgBurn can do both. ImgBurn
    can also just do a plain copy of the audio CD as well via an ISO image.
    Yes, I've used ImgBurn to do that and it works very well. I downloaded Cdex and In about 5 minutes did a test copy and rip...not bad at all, seems solid. Do you think this will have problems in a 64B environment? I'm migrating to 7 Ultimate and want to do 64B.
  1. How to rip dvd audio to mp3 or wav files?
    By babypotato in forum DVD Ripping
    Last Post: 17th Jul 2011, 03:22
  2. convert dts 5.1 wav to ordinary mp3 etc.
    By flannob in forum Newbie / General discussions
    Last Post: 15th Sep 2010, 05:02
  3. How to convert WAV/MPA/MP3 to AC3 6 channels?
    By katalogas in forum Audio
    Last Post: 16th Feb 2010, 14:12
  4. Replies: 6
    Last Post: 5th Nov 2008, 19:07
  5. Replies: 1
    Last Post: 11th Sep 2008, 20:06
