VideoHelp.com Forum
Results 1 to 16 of 16
  1. Is it possible first off to put 720p on standard DVD and if so can it be played back in hd on a blueray player? If not why? I have done a fair amount of research here and elsewhere and have not found any satisfactory answers. Thanks
    Multi-AVCHD will let you put 720p material on a standard DVD in the AVCHD format, which is playable on many bluray players and the PS3. It will not play on a standard DVD player.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member Cornucopia's Avatar
    Neither 720p, 1080i nor 1080p are supported AT ALL on compliant, official SD DVD-Video discs.
    If you put 720p material on a Data DVD disc, and your bluray player can read the disc and parse the filesystem and supports the 720p's file format - yeah - it'll play.
    Or do AVCHD/AVCREC for BD-9 (again, assuming your BDplayer supports it).
  4. Thanks for the answers. So assuming that I can put 720p avchd ( i have vegas 8 which I believe supports this format) onto a standard dvd and my bluray can read it and play it, will it then play in hd?
  5. Member fritzi93's Avatar
    Yes, *if* your player supports AVCHD, BD 5/9 etc. What specific model of standalone BD player do you have?
    Pull! Bang! Darn!
    Maybe. Some BluRay players support AVCDH, some do not. Some BluRay players won't play AVCHD discs but they will play BluRay format burned to DVD media. And still others may not play the discs no matter what you do. You just have to try and see what your player likes.
    If you are going to be burning to DL media, we would strongly recommend the use only of Verbatim DVD+R DL discs and the use of ImgBurn (it's free) for burning.
  7. Hey guys I have a Panasonic DMP-BD601. It apparently supports AVCHD and BD. Oh and why Verbatim? I hate Vebatim. They owe me $10 on a rebate they gyped me out of. Any way thanks for the comments.
  8. Member Cornucopia's Avatar
    Because they seem to be consistently better supported in readability, particularly as regards DualLayer. There are a few other good brands/formulations, but they are neither as inexpensive nor as commonly found as Verbatims.
  9. Member fritzi93's Avatar
    Yeah, it's been the experience of most members here that *only* Verbatim makes a reasonably reliable DVD+R_ DL disc. They're simply more difficult to make than single layer discs. It's something of a miracle that a dye-based dual layer disc works at all. Pressed dual-layer discs are an entirely different thing.
    Pull! Bang! Darn!
    I recommend AVCHDcoder; but of course there is Ripbot, Gotsent, Multiavchd & BDRebuilder that all make AVCHD’s. I haven’t seen a player Blu-ray player that hasn’t played AVCHD; however some brands like Samsung will not play DVD +R only DVD –R. I’ve used Ritek DVD –R DL from Newegg with only 2 or 3 coasters out of 50; while I’d prefer Verbatim they are about $2.00 a piece for DVD –R DL. I’ve tried a new brand for DVD+R (from newegg) called Optical Quantum reasonably priced & have had no problems thus far.
    jimdevo you state “have done a fair amount of research here and elsewhere and have not found any satisfactory answers.” I don’t see how this is possible since making AVCHD’s are all over this forum & tutorials at the top of the home page.
    http://adubvideo.net/how-to/backing-blurays-avchdcoder
    http://www.videohelp.com/guides/cate...vchd-4;72#4;72
    Enjoy!
  11. Everything I say is false koberulz's Avatar
    I've been looking into them for printable Blu-Ray discs and that does seem to be the consensus opinion for those. Doubt their DVDs would be any different.
    They make them in printable form for DVD in this brand too but I do not know about BD. As for a source in the USA here is a link http://www.newegg.com/Product/Produc...e=&srchInDesc=
  13. Everything I say is false koberulz's Avatar
    I do know they make printable Blu-Ray, they showed up when I was googling. Having trouble getting them to Australia, though.
    However, this isn't my thread.
  14. [quote="a1677c"]I recommend AVCHDcoder; but of course there is Ripbot, Gotsent, Multiavchd & BDRebuilder that all make AVCHD’s. I haven’t seen a player Blu-ray player that hasn’t played AVCHD; however some brands like Samsung will not play DVD +R only DVD –R. I’ve used Ritek DVD –R DL from Newegg with only 2 or 3 coasters out of 50; while I’d prefer Verbatim they are about $2.00 a piece for DVD –R DL. I’ve tried a new brand for DVD+R (from newegg) called Optical Quantum reasonably priced & have had no problems thus far.
    You are changing the op. I did not know that you had to convert a video to avchd or record it to avchd in order for it to play on a bluray in hd from a regular dvd. I did not know anything about avchd...but you know what? I do now!
    I know this isn't the same as a program but if you get an upscaling dvd player, it will upscale whatever disc to 720, 1080i and 1080p. I have one of the best upscaling dvd players and it works great, though everything I've burned wasn't in original quality.
  16. Member edDV's Avatar
    I think AVCHD export started with Vegas Pro 9, not 8.
    http://www.kiva.org/about
  1. Any DVD or BlueRay players play HD avi's?
    By destro_99 in forum DVD & Blu-ray Players
    Last Post: 22nd Dec 2010, 08:38
  2. standard 720x480 DVD to Avi 720P with free converter?
    By MilesAhead in forum Video Conversion
    Last Post: 26th Apr 2010, 17:44
  3. Replies: 1
    Last Post: 19th Feb 2010, 14:10
  4. Standard Backup DVDs freezing on my new Sony BlueRay BDP-S550
    By bribri25 in forum DVD & Blu-ray Players
    Last Post: 5th Jan 2009, 13:46
  5. If I record in Widescreen 16:9, how will a DVD play on a Standard 4:3 TV?
    By syberkill in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 3rd Jun 2008, 10:03
