I am looking for a simple cutter. I used to run VirtualDub on SD DV capture:
mark beginning, mark end, delete
I only cut at I-frames so I've always used direct stream copy, no re-encoding.
Is there such software for AVC HD?
thanks!
Results 1 to 12 of 12
Thread: AVCHD MTS Cutter
Try the free TSSniper or TS-Doctor . Or trialwares: Transport Stream Packet Editor, Smart Cutter Ps/Ts or latest videoredo beta , http://www.videoredo.net/msgBoard/sh...ad.php?t=15759 .
H264TS_Cutter is another choice. I tested it awhile back and it worked.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
I've tried TSSniper. It does not have keyboard shortcut. The concept there is you pick area to save (not to cut out) and export at the end. The resulting file lose the metadata (e.g. original data/time). So I don't think it's suitable.
I will try the others.
TSSniper can be used in either cut mode or scene mode, whichever is preferred. You can change the default in settings. I've tried h264ts_cutter as well and thought it made ugly cuts that introduced extraneous noise. (YMMV :P ) And none of the freeware basic H.264 editors are frame-accurate. [shrugs]
Pull! Bang! Darn!
How do you set TSSniper in cutting mode?
setting -> generic behavior
default operation mode for new project = cut mode
default scene definition for new project files = file content is defined as cut
Still cut options are all greyed out.
Anything am I missing?
thx
Settings -> General -> Default scene definition for new project files ->
File content is defined as scene
or
File content is defined as cut.
I use Scene mode, you first clear the right-hand pane, then set in and out and add a scene to the right-hand panel. Repeat as necessary. For cut mode you define in and out for the cut and remove it from the project. It works pretty well with a little practice, good enough to remove adverts, although not accurate.
But that doesn't address your other concern, about which I'm not clear.
TSSniper will index the material to be kept, merge it and export as a *.TS file. (H.264 transport stream).
Pull! Bang! Darn!
The MTS file header contains metadata such as original data/time. Right now I don't have a tool that can extract metadata in editor (dvdate no longer works in Premiere). However, I'd think it will be available later so I'd like to keep the metadata in the header in the exported file.
Doesn't your AVCHD camera come with s/w for basic cutting / editing? That's probably your best bet if you want to retain metadata.
Canon comes with Pixela ImageMixer and ZoomBrowser. It does not look like they have any video function at all.
I tried TSSniper again. It actually saves the header correctly.
The cut mode is really cut -- it just put the entire video as cut out to start with and you still add them back as it goes.
My complaint is:
You can't drop mts file on it.
There is no keyboard shortcut for setting in/out
Looking at TS Doctor. I have mts files from Canon. It first go through checks and ask me to convert from 192 byte packet to 188. Do I loose any information here?
I actually can't figure out how to use it. The cutter support 3 sections. However, I don't have a clue on how to export the result.
One more issue with TSSniper: it saves .ts file which is not recognized by Premiere. I have to rename them to .mts. Any way to make it use mts extension?
Thanks!
AVCHD - join MTS files
By cmichel04 in forum Camcorders (DV/HDV/AVCHD)Replies: 9Last Post: 26th May 2011, 11:55 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
AVCHD (*.MTS) to MPEG-2 conversion
By keesio in forum Video ConversionReplies: 39Last Post: 30th Sep 2009, 12:23 -
Looking for software to use as an AVCHD frame cutter
By sebaz in forum EditingReplies: 2Last Post: 19th Sep 2009, 14:29 -
Lossless h.264 or avchd cutter
By yardline in forum Video ConversionReplies: 2Last Post: 4th Oct 2008, 10:21
