VideoHelp.com Forum
  1. Hi all.
    About to shoot a project in 720p.
    I want the source video footage in this resolution. Then I want to convert it to 480 resolution to edit in Sony Vegas, and burn a DVD in 480i.
    I know I'm going to be asked why bother downconverting...it's because I only want the project distributed on DVD for now. If in the future someone does something with it, the source material will be in HD.
    Anyway, what is the best (and I'm also looking for cheapest) way to convert from 720p to 480i for editing?
    Shooting in P2, so files will be in mxf format. I'd like uncompressed video if possible when downconverting.
    I have a windows 7 pc. I do, also, have the option of using a mac, but i'd like to use a pc if possible.
    Thanks in advance.
  2. Member edDV's Avatar
    What was the camcorder. Was it able to shoot 1280x720p/59.94?
    If so... it should be possible but I haven't attempted it yet.
    You would downscale to 720x480p/59.94, then export encode as MPeg2 720x480i/29.97 top field first.
    http://www.kiva.org/about
    Why would you want to interlace your natively progressive video?
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    Probably because his goal is standard DVD-Video , and it doesn't support 60p, and he wants to keep 60hz temporal resolution
    Just beyond my scope of knowledge. Thanks PDR...
    Have a good one,
    neomaine
  6. Member edDV's Avatar
    DVD only supports 480i/29.97 or 480p/23.976
    Since his source is camcorder 59.94p, inverse telecine isn't an option.
    It is possible to "fake" 29.97p by encoding it to 29.97i. This would be done for web delivery, etc. by effectively tossing every other frame. Otherwise, interlace 480i preserves 59.94 field motion samples per second.
  1. Converting 720p to 480p (maybe even 480i) Need how-to procedure
    By TheNomad63 in forum Newbie / General discussions
    Last Post: 7th Dec 2010, 01:43
  2. Replies: 15
    Last Post: 28th Sep 2010, 07:34
  3. 1080/60i to 720p (for AVCHD Disk) and 480i (For DVD)
    By greymalkin in forum Video Conversion
    Last Post: 25th Jun 2010, 06:06
  4. 1080p downconvert to 720p during playback, is this possible?
    By Modify_inc in forum Newbie / General discussions
    Last Post: 4th May 2010, 01:53
  5. Replies: 15
    Last Post: 28th Feb 2008, 14:54
