VideoHelp.com Forum
    Hello everyone,
    I have 2 CUE and Ape files on my drive. I tried everything but I can't extract or burn them.
    First I used PowerISO 4 to burn them. I know Poweriso supports CUE but I get an error that this CUE file
    isn't supported. Then I tried NERO. NERO couldn't open the CUE or APE file.
    Then I tried EAC. EAC could not open the file. It said 'error'.
    I think these CUE files are protected by something. Or somebody packed in these CUE files very wrong.
    Maybe something important: these CUE files are made with: Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
    I think someone protected these CUE files with that version.
    I have EAC 0.99 beta 5 on my PC. Why I can't get this working?
    So help me to extract these CUE or APE files!
    Thanks by advance.
    Diets
  2. Member t0nee1's Avatar
    Try Imgburn and burn an Audio CD from the CUE file(s)..
    There's also foobar2k with APE plugin..Import the CUE or APE files in f2k and play or convert them..If the CUE sheets were properly created , it should/will work..
    http://forum.imgburn.com/index.php?showtopic=5555
    http://www.afterdawn.com/guides/arch..._ape_files.cfm
    http://www.foobar2000.org/components
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
    open the cue with notepad and see what format it expects the files to be in. you may have to convert them to wav to get it to work.
    Many thanks!
  1. Replies: 7
    Last Post: 12th Dec 2009, 10:12
  2. How to burn a .iso/bin,cue with nero
    By Chupes in forum User guides
    Last Post: 9th Sep 2009, 20:33
  3. Can you burn a CD-extra using .cue file?
    By piano632 in forum Audio
    Last Post: 15th Feb 2009, 21:45
  4. Problem with APE file
    By Gregg in forum Audio
    Last Post: 3rd Sep 2008, 06:30
  5. Cutting avi's with APE 3?!
    By B-Twien Bytes in forum Newbie / General discussions
    Last Post: 29th Sep 2007, 12:35
