Hi,
I downloaded an .avi. I tried to use adobe premier to convert but no audio came out. I tried the same with cheetah DVD burner. Great picture quality but no sound. What the heck is going on,.
Thanks.
BTW - I also have DVDit pro. Shouldn't an avi file go in it (or just mpeg-2 files). It seems to recognize it as a pal file but it isn't (I think.)
Results 1 to 11 of 11
Thread: no audio when i convert
its an mpeg layer-3. I know I have that codec because it plays fine on my computer.
You don't say what you are trying to convert to. DVD, I assume? If you want it to play on a stand-alone DVD player (not computer), the audio stream should either be ac3 or wav. And it would have to be in a DVD-compliant file structure.
Did you try any of the converters recommended by Baldrick?
Downloaded avi files are likely far from any sort that can be processed very well by DVDIt Pro. The .avi container is widely used for a number of different video formats.
i downloaded avs to dvd. its a little daunting to go through but i tried. i didn't make a dvd for 2 reasons. one - said it was going to leave a watermark.
2nd** like I said, im no techie but how does a 700mg .avi file turn into a 15gb file??
i just want to take one movie file and make it into a dvd. is there any easy way??
You can try DVDFlick, FAVC , or convertxtodvd ($) , these are very easy to use softwareOriginally Posted by rksherk
AVStoDVD does not leave watermarks, so I suspect you have downloaded something else.
oh, i guess i installed avs authoring program. not sure how that happened or what the difference is. BTW - here is another big mystery from me you could help with.***
I combined some avi on adobe premiere and make one file. Some of the audio plays on the new file and some doesn't... any reason why??
thanks
How were the avi files encoded ?
What video codec ?
What audio codec ?
Does the audio play on the premiere timeline ?
What compression did you use when you output the files ?
sorry... i was away. the video is divx the audio is mpeg layer 3. the audio doesn't play on the timeline and i can't even render the audio because (i guess) all .avi are blank. i don't look at compression (not sure about all that.) Like I said, I just try to fool around but sometimes it gets frustrating.
thanks
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 18:28 -
Convert MKV with ACC audio to AC3 audio for PS3 playback
By wolvie77 in forum Video ConversionReplies: 4Last Post: 25th May 2010, 10:13 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 21:52
