Here is the deal:when demuxing AAC Audio from an mp4, is it possible to to demux straight to a wav file and then to AC3, thus saving an intermediate step?
You say. Of course, that is easy. Well, the goal is to save as many generations as possible-- the less encoding the better.
If I want to encode the aac to ac3 for DVD muxing, doesn't it sound ludicrus if I have to go from demuxing a mp4(h.264/mpeg 4 avc) track with YAMB to creating a wav file with another program and then using AFTEN or AFTEN Gui a little repetitive? I know that DGAVCindex can demux as well--and demux the audio straight to a wav file if I am not mistaken---and DGAVCdecode is the avisynth decoder I use for encoding BUT the DGAVCindex only likes raw h.264, thus making YAMB a good first step for demxuing the tracks to raw (MAYBE--and that is a big maybe).
You see, when it comes to AVI, eveyone can use virtualdub to save the audio to a WAVE. Good for AVI's/ Now let's get back on track.
MP4's can't be fed into virtualdub yet.
Are you stating to understand my point now? Wouldn't it be nice if there was a program that could take the mp4 (h.264/mpeg 4 avc) and extract the audio to a wave and then have the h.264 go to a raw h.264 for DGAVCindex? I mean, the MKVextract, does exactly what I want to do BUT i have an mp4 not MKV. Virtualdub can do this for AVI's. But mp4, it looks like I am stuck with a reptitive step or a tripple encdoing of audio.
IF YOU CANNOT UNDERSTAND MY POINT, HERE IS A STRAIGHT TO THE POINT VERSION BELOW:
Here is my illustration for Audio AAC to ac3 for DVD in an mp4 container
YAMB ---> ANOTHER PROGRAM TO ENCODE IN WAV--AFTEN or AFTEN GUI for AC3 dvd specs.
This is what I want to happen
PROGRAM 1 (demuxes to raw h.264 AND saves audio as wave)--- Program 2 (AFTEN wav to ac3)
My analogy:
Since there is a way to do this with an MKV (mkvextract), wouldn't you think there would be the same process for mp4 (h.64) files so you could save one generation of audio encoding?
I am saying:
I WISH you could feed DGAVCindex wih a regular mp4 h.264 then that would save me a step and one less encode. Actually, steps are great. Degrading one generation of audio--not that great. But unfortunately, the h.264 has to be demuxed to raw h.264 with another program such as yamb before it can be loaded into dgavcindex.
Conclusion:
Is there any way around this so there is one less step of encoding the audio. Encoding the audio 3 times sounds ludicrus if you know what I mean. And what do I mean by encoding audio 3 times--demxuing audio from mp4 to aac-->aac to wav--->wav to ac3. Now, that we are on the same page--anyone want to offer any suggestions?
mp4_to_ac3.zip
Ffmpeg at a high enough bitrate (320k or higher) will sound just as good as Aften's ac3 transcoder
If you insist on using Aften, download this instead
mp4_to_wav_to_ac3.zip"Quality is cool, but don't forget... Content is King!"
You realize that the first step from AAC -> WAV doesn't lose anything? It just relies on the "accuracy" of the decoder to re-create the original stream ... trying to do it all in one step just relies on something else to "internally" decode to wave file then re-compress it again.
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Help With Batch Encoding Multiple DV files to h.264 MP4's.
By mpalm887 in forum Video ConversionReplies: 2Last Post: 27th Jan 2010, 23:02 -
h.264/MP4 w/AC3?
By climbs in forum DVD RippingReplies: 17Last Post: 2nd Nov 2009, 19:10 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09 -
MP4 AVC/H.264 encoding
By Jacobus Serpenti in forum Video ConversionReplies: 17Last Post: 1st Jan 2009, 08:18
