VideoHelp.com Forum
    Hi everyone. I have 3 movies converted from .avi to .vob, .bup and .ifo format and I wanted to compress them so I didn't have to use 3 separate dvds to burn them on. I've realised I might not be able to put all 3 onto 1 disc because the picture will look off, so my question is just how do I compress my .vob or .ifo files to the smallest compression rate? I have dvd shrink 3.2, how can I use that? Will I need to mount all my files to a virtual drive? Will I need to download extra software to convert the files into some other format first? Thanks very much!
    Assuming you have each DVD ripped to your HDD in separate Video_TS folders, you can use the re-author mode in DVD Shrink to import each title, drag from the right to the left hand panes, then create a new title.
    Be aware though - re-author mode means no menus.
    If you did want to go down this path, and are happy with no menus, I would use DVD Shrink to re-author, but set the compression to No Compression. Create a big, oversized DVD, then use DVD Rebuilder to do the actual compression. It will take longer, but the results will be far better. I would also be targeting a DVD9 for three movies. The quality will still be very average, but better than using a DVD5.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member netmask56's Avatar
    If you still have the avi files you could save a few steps by using a program like ConvertXtoDVD to make the VIDEO_TS folder ready to burn. Just add the 3 avi's as separate titles. You can have a menu and chapters etc.
    TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung LA40R7 LCD TV ~ Windows 7 & MAC G4
    Better still, if you still have the avi files get a DVD player that can play them, and don't convert at all.
    Thanks guys, it all worked out.
  1. VOB files to a DVD-IFO file?
    By verdikt in forum Authoring (DVD)
    Last Post: 26th May 2011, 13:03
  2. How do you make a DVD from only some VOB & IFO files?
    By JoeBolden in forum DVD Ripping
    Last Post: 12th Mar 2009, 00:12
  3. Function of .IFO .BUP .VOB files on a DVD?
    By brassplyer in forum Authoring (DVD)
    Last Post: 14th May 2008, 21:27
  4. Replies: 3
    Last Post: 28th Sep 2007, 15:04
  5. Replies: 4
    Last Post: 20th Aug 2007, 13:38
