VideoHelp.com Forum
    First of all hi to all of those who are willing to help me out...!!!
    I googled up and tried searchin loads of forums but none of the places i got d answer ...for 2 hrs i was just stuck up nd found nothing (may b my bad luck )...
    1. I'm playing a MKV file with softcoded subtitle (u cn turn em off) using media player classic, everything is workin fine bt m' not able to view subtitle (As i want to take screenshot with subtitle on using MPC ).
    So please help me in this or else some other way to take out multiple screensot (with subtitle on)of a MKV file then let me know.
    2. How can I remove or edit subtitle for MKV file..??
    I changed the subject. You CAN already play mkv but not take screenshots with subs...huge different. .
    1. Try VLC instead. It should be able to capture the subtitle also. Video->Snapshot.
    2. Use mkvtoolnix to remove subs and also demux subs from the mkv so you can edit them.
    VLC screenshot example with soft subtitles:
    Thanks Baldrick...u are always quick to help out...
    1. I'm able to take screenshot using MPC but not able to view subtitle...Is there any way (Using MPC) if not then no problem coz MPC can take multiple screenshots thats why was preferring it.
    2. Is there any topic for using mkvtoolnix so that i can know more about it..!!
    Cheers
    Is there a option of taking multiple screenshot in VLC ???
  5. Is there a way in VLC to go through each frame in the video so that i can take precise screenshots to be made into an animated gif.
  1. Replies: 2
    Last Post: 2nd Feb 2012, 00:48
  2. Subtitle not working in MPC HC
    By majid_aryaee in forum Subtitle
    Last Post: 13th Oct 2010, 10:43
  3. MPC only show the first subtitle in mkv file...
    By newguy08 in forum Subtitle
    Last Post: 11th Jul 2010, 10:21
  4. screenshot from mkv files
    By dtommy79 in forum Software Playing
    Last Post: 14th Feb 2010, 11:33
  5. Replies: 0
    Last Post: 26th Jan 2009, 14:59
