I just ripped star trek to a 1.7gb file with dvdfab using standard settings and it looks terrible for being that large of a file. Is there something i can do to make it better? will doing a .mkv be better?
Results 1 to 12 of 12
Thread: Best quality rip
Perhaps the resolution you set was too low? A high bit rate on a low-res setting will yield poor results if you decide to blow the result back up x2+. More details please.
[For comparison, I squashed the a Blu-Ray source version of the new ST movie down to 2 GB, keeping the 1920x1080 resolution, and it looked quite nice. Yes, I know that's probably too low a bit rate for that res., but it came out great nevertheless. I made a second copy at 5 GB and I had a difficult time seeing any difference. (Viewed on a 30" Dell 3008, full screen).]
1.7gb isn't large at all if you're talking about dvd mpg2..it's actually much too small, which would explain terrible results.
you sure you didn't rip the dvd under "dvd to mobile" ?
I made it a .avi under DVD to mobile(generic) with at like 770x400ish doing about 1200kb/s. Would a DVD to DVD not just get me cloned dvd?
dvd to dvd would get you the same quality as what is on the DVD. based on your last response I'm guessing this isn't what you want, but all I can do so far is guess since you never really said what you want the output to be :P
DVD to DVD is indeed and exact copy of the DVD...and that is a "rip". What you are doing is "converting" and degrading the quality.
Hello all
I am not a techno-wiz with regards to DVD ripping and would like to ask your assistance.
I am trying to put my DVDs onto my MVIX780HD, as close to the original DVD as possible. Problem is that the movie stutters whether the movie files are an ISO copy or a Full Disk copy. (I used used DVDFab when DVDShrink was not up to the job).
I have browsed a few threads and comments on the web, however I cannot find a definitive answer.
I am at my wits' end as I cannot seem to elude the stuttering. Your assistance is appreciated.
Hola!
An MVIX 780 HD is a harddrive-based network multimedia player.
Does that then mean the result is being streamed across the network? If yes, that is where to start looking (at the network)
Want to rip from interlaced DVD's in highest/same quality!
By DARkTYranno in forum DVD RippingReplies: 17Last Post: 22nd Feb 2012, 16:05 -
Rip DVD's without quality loss - is it possible?
By Rolf212 in forum DVD RippingReplies: 6Last Post: 19th Feb 2012, 08:47 -
Better rip quality- how?
By mst in forum Newbie / General discussionsReplies: 9Last Post: 9th Dec 2011, 17:17 -
rip to mp4. quality
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 25th Apr 2011, 05:11 -
Rip DVD to DIVX with the same quality
By jujuandhuhu in forum DVD RippingReplies: 20Last Post: 12th Apr 2008, 13:43
