Hi, I have a tv series with 24 episodes on my HDD. Each episode is around 350MB, and I would like to burn the whole series to DVDs (preferably using around 4 standard 4.7GB DVD+Rs). The files are in .avi format and I understand that this has to be changed? I would also like to create a DVD menu which allows you to choose which episode on the disc you would like to watch (I know that this further limits the amount of episodes that I could get on one disc). Keeping the quality around what it is at the moment is also important to me. I was wondering if anyone could guide me in the right direction. Any help would be much appreciated. Thank You.
Individual file size: approx 350MB
File Format: .avi
Thread: Creating DVD from .avi files.
The size of the AVI file has little bearing on the converted MPEG file size. The running time is the most important. Say you have 24 files with a running time of 30 minutes each = 720 minutes total. Divided by four = 180 minutes per disc. Best quality is about 60 minutes, good quality 120, so it would probably work on 4 DVDs of 4.37GB each. If you plug in 180 minutes and 4.37GB to a bitrate calculator ( Videohelp Bitrate Calculator):
You can see the predicted bitrate is about 3160Kbps. A bit on the low side, but probably OK, depending on your original AVI quality. (I assume Xvid/Divx for AVI type format.) If you total running time is longer than I guessed, then that bitrate will drop rapidly. Below about 2000 quality drops off even more rapidly.
You can try encoding a short representative clip of one of the episodes and see how it looks. If really bad, then you may need to use more discs. If the original format is Divx/Xvid, a set top Divx player would save you a lot of time, though you may not end up with menus.
But the simple answer is to try one of the All-in-one converters here: http://www.videohelp.com/tools/secti...dvd-converters ConvertX would be my first choice, but for freeware, AVStoDVD or DVD Flick or FAVC are popular around here.
And welcome to our forums.
It is longer than you guessed, the total runtime is 1080 minutes. 6 discs with 180 minutes on each is fine. I will give it a try, thanks.
Or ... you could get the Philips dvp5590 DVD player ... and just put about 12 of them AVI videos ... at a time ... on a DVD disk and watch them on a DVD Player that plays Divx videos.
When I do have avi videos to make into a real DVD Video disk ... I use the program ... ConvertXtoDVD 4.
I put about 4 episodes on ... one hour TV shows without commercials are about 41 minutes. So ... 4 x 41 = 164 minutes ... which is 2 Hours and 44 minutes.
Quality will not be that great. When I use ConvertXtoDVD 4 ... I have it use the DVD9 specification and then if it is bigger than a DVD5 ... I use DVDShrink or DVD Rebuilder ... to get it to fit on DVD 5.
Creating Menus on avi files
By zammil in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2010, 13:27 -
do my AVI files need to be "pre-processed" before creating DVD?
By EtherJones in forum Video ConversionReplies: 3Last Post: 11th Jun 2010, 00:46 -
Creating DVD-Video from 6 AVI files
By rock_king_my in forum Authoring (DVD)Replies: 4Last Post: 9th Jun 2010, 21:42 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
Noob question about creating SRT files from an AVI
By Seroster in forum Authoring (DVD)Replies: 2Last Post: 30th Aug 2007, 14:03
Statistics
Newest guides
Latest tool updates
New media comments
