I needs some help with a .3gp file; which i deleted of my phone ; but which i have recovered with some recovery software.. Now none of the programs (mpc ;klmcodec416 ;WMP) will play it.. Its probably damaged.. Can somebody advise what to use to fix something like this??
I really need those files...
Appreciate any help!
This is the details screen for a working file ;
General
Count : 265
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Count of video streams : 1
Count of audio streams : 1
Video_Format_List : MPEG-4 Visual
Video_Format_WithHint_List : MPEG-4 Visual
Codecs Video : MPEG-4 Visual
Video_Language_List : English
Audio_Format_List : AMR
Audio_Format_WithHint_List : AMR
Audio codecs : AMR-NB
Audio_Language_List : English
Complete name : C:\Documents and Settings\XPPRESP3.USER\Desktop\Video004.3gp
Folder name : C:\Documents and Settings\XPPRESP3.USER\Desktop
File name : Video004
File extension : 3gp
Format : MPEG-4
Format : MPEG-4
Format/Extensions usually used : mp4 m4v m4a m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
Format profile : 3GPP Media Release 5
InternetMediaType : video/mp4
Codec ID : 3gp5
Codec ID/Url : http://www.3gpp.org/
Codec : MPEG-4
Codec : MPEG-4
Codec/Extensions usually used : mp4 m4v m4a m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
File size : 3915776
File size : 3.73 MiB
File size : 4 MiB
File size : 3.7 MiB
File size : 3.734 MiB
Duration : 15680
Duration : 15s 680ms
Duration : 00:00:15.680
Overall bit rate : 1997844
Overall bit rate : 1 998 Kbps
Stream size : 24974
Stream size : 24.4 KiB (1%)
Stream size : 24 KiB
Stream size : 24.39 KiB
Proportion of this stream : 0.00638
Encoded date : UTC 2010-01-17 00:06:08
Tagged date : UTC 2010-01-17 00:06:08
File creation date : UTC 2010-01-16 22:06:08.000
File creation date (local) : 2010-01-17 00:06:08.000
File last modification date : UTC 2010-01-16 22:06:24.000
File last modification date (loc : 2010-01-17 00:06:24.000
Video
Count : 152
Kind of stream : Video
Format : MPEG-4 Visual
Format profile : Simple@L4a
Format settings : BVOP
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : 0
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
InternetMediaType : video/MP4V-ES
Codec ID : 20
Codec : MPEG-4V
Codec : MPEG-4 Visual
Codec/Family : MPEG-4V
Codec/CC : 20
Codec profile : Simple@L4a
Codec settings : BVOP
Codec settings, BVOP : Yes
Codec settings, QPel : No
Codec settings, GMC : 0
Codec settings, GMC : No warppoints
Codec settings, Matrix : Default (H.263)
Duration : 15436
Duration : 15s 436ms
Duration : 00:00:15.436
Bit rate mode : CBR
Bit rate mode : Constant
Bit rate : 2003436
Bit rate : 2 003 Kbps
Nominal bit rate : 2048000
Nominal bit rate : 2 048 Kbps
Width : 640
Width : 640 pixels
Height : 480
Height : 480 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.333
Display aspect ratio : 4:3
Rotation : 0.000
Frame rate mode : VFR
Frame rate mode : Variable
Frame rate : 14.576
Frame rate : 14.576 fps
Minimum frame rate : 2.433
Minimum frame rate : 2.433 fps
Maximum frame rate : 18.166
Maximum frame rate : 18.166 fps
Frame count : 225
Resolution : 8
Resolution : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.447
Stream size : 3865714
Stream size : 3.69 MiB (99%)
Stream size : 4 MiB
Stream size : 3.7 MiB
Stream size : 3.687 MiB
Proportion of this stream : 0.98722
Language : en
Language : English
data_partitioned : No
Audio
Count : 132
Kind of stream : Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format/Url : http://www.apple.com/quicktime/download/standalone.html
Format profile : Narrow band
InternetMediaType : audio/AMR
Codec ID : samr
Codec ID/Url : http://www.apple.com/quicktime/download/standalone.html
Codec : samr
Codec : AMR-NB
Codec/Info : AMR narrow band (3GPP)
Codec/Url : http://www.apple.com/quicktime/download/standalone.html
Codec/CC : samr
Duration : 15680
Bit rate mode : CBR
Bit rate : 12800
Bit rate : 12.8 Kbps
Channel(s) : 1
Channel(s) : 1 channel
Sampling rate : 8000
Sampling rate : 8 000 Hz
SamplingCount : 125440
Resolution : 13
Resolution : 13 bits
Stream size : 25088
Stream size : 24.5 KiB (1%)
Stream size : 25 KiB
Stream size : 24.50 KiB
Proportion of this stream : 0.00641
Writing library : Nokia 0
Writing library/Name : Nokia
Writing library/Version : 0
Language : en
Language : English
and this for the DAMAGED FILE which i want to repair;
General
Count : 265
Complete name : F:\Recovered FAT Partition 1\[00000021]\Video000.3gp
Folder name : F:\Recovered FAT Partition 1\[00000021]
File name : Video000
Format/Extensions usually used : m4v mp4v
Codec/Extensions usually used : m4v mp4v
File size : 1015103488
File size : 968 MiB
File size : 968 MiB
File size : 968 MiB
File size : 968 MiB
File size : 968.1 MiB
File creation date : UTC 2009-02-15 16:50:06.000
File creation date (local) : 2009-02-15 18:50:06.000
File last modification date : UTC 2009-02-15 05:18:30.000
File last modification date (loc : 2009-02-15 07:18:30.000
Video
Count : 152
Format profile : Advanced Simple@L5
Codec : MPEG-4V
Codec profile : Advanced Simple@L5
Width : 640
Width : 640 pixels
Height : 256
Height : 256 pixels
Display aspect ratio : 2.500
Frame rate : 23.976
Frame rate : 23.976 fps
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Interlacement : PPF
Writing library : XviD0047
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Writing library/Name : XviD
Writing library/Version : 1.2.0.dev47
Writing library/Date : UTC 2006-11-01
I dont know how to fix this... Anybody have another idea please...??
Thanks in advance!!
Results 1 to 1 of 1
Thread: corruptd .3gp file
A corrupt file after sending a .3gp file via bluetooth
By ViDector in forum Video ConversionReplies: 3Last Post: 15th Aug 2011, 09:03 -
Help me save an important .3gp file!
By tempestkeep in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2010, 11:10 -
Any way to fix a 3gp file
By fevs in forum Newbie / General discussionsReplies: 0Last Post: 17th Aug 2010, 06:26 -
3GP file size
By Jean777 in forum AudioReplies: 3Last Post: 24th Feb 2010, 16:36 -
.3GP File currupted o unsupported
By MikeDinner in forum EditingReplies: 2Last Post: 31st Mar 2009, 04:02
