VideoHelp.com Forum
    I recently purchased the DVP3360 mainly to playback avi files from the usb slot. Tried it today and the picture quality was quite poor compared to the same file being played on my PC. My television is not HD but it's not really old either, the dvd player is connected by scart to the TV.
    The movies aren't choppy but they are very fuzzy, and some have little changes of colour in bright areas.
    Any help would be appreciated
    Are you watching on the same size screen from the same distance? When you enlarge a small frame to a large screen the defects become more noticeable. So if you're comparing watching in a 640x360 window on your computer monitor to full screen on a 32" TV (from the same distance) the bigger TV will look worse. It will be fuzzy and you will be more likely to see DCT ringing and macroblock artifacts.
    Another issue that may have some bearing: computer monitors have very different gamma curves compared to television. If someone adjusted the color in the Divx file to look good on a computer monitor it may look overly bright and washed out on a TV.
    I recommend you rip a DVD then convert it to high quality Divx yourself. Then compare your Divx file to the DVD. That will tell you if the problem is in your Divx/DVD player.
  1. Philips DVP3550K Can't Playback VOB with Subtitles through USB
    By audiobean in forum DVD & Blu-ray Players
    Last Post: 30th Dec 2010, 02:27
  2. Replies: 3
    Last Post: 20th Jun 2010, 19:23
  3. Very poor performance on ATi 650 USB PLZ HELP
    By Marto2008 in forum Capturing
    Last Post: 16th Jun 2010, 18:54
  4. Philips DVP3360 Region Unlock Code
    By The Khemist in forum DVD & Blu-ray Players
    Last Post: 11th Dec 2009, 18:14
  5. DVP5990-37.. poor avi decompression playback quality?
    By Gareee in forum DVD & Blu-ray Players
    Last Post: 7th Jan 2009, 13:34
