Hi I want to create a multichanel dvd with mi own music , how can I do it? I have it in 6 wav mono chanels, the video doesn t matter, can somebody helps me ?![]()
Thread: 6 wav to DVD with surround sound
Use something like Aften with one of the GUIs to encode the 6 mono wavs into a 5.1 AC3 audio track, then use an authoring tool to create the DVD. You will have to put a video with the audio, but this could be a still image or a black frame. Either will use very little bitrate.
How did you create the 6 mono wavs ?
Do you know which channel is which ?
How did you create the LFE channel ?
Thanx guns1inger a will try it , it doesn t matters wich cahannel is which, i just need to have separated tracks. I ll tell you wath happened thanx again....
So you are creating a 6 channel mono audio track ? What's the point ? If the amp has Dolby Pro Logic, or better yet, Pro Logic II, it will do a far better job creating fake surround that what you are trying to do.
hello
i have the same problem. i have 5 mono wav files (exported from abletons live). then i import the 5 files in soundtrack pro and export them as a 6-channel-wav (without lfe). my problem is now: how can i burn this 6-channel-wav-file on a dvd, so that i can hear the 5 different files on the separated loudspeakers (lf,rf,c,lr, rr) of my dvd-system (jvc th-g31).
thanks for helping!
Create a DVD Video with a simple black video or still image that requires very little bitrate
i know. but i don't know with witch program it works...
Any authoring tool - DVD Styler, GUIForDVDAuthor or any commercial tool. You can create the video with a simple avisynth script and HCEnc
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 1Last Post: 10th Jan 2011, 23:04 -
No Right Surround Channel when transcoding AC3 -> WAV
By SliceOfHorse in forum AudioReplies: 8Last Post: 21st Aug 2009, 15:29 -
DVD to AVI with surround sound
By Sutekh in forum Blu-ray RippingReplies: 1Last Post: 12th Aug 2009, 12:47 -
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2009, 12:46 -
5.1 Surround Sound on DVD
By Adhishyajnik in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:57
