I want to transfer Hi8 to miniDV using a Sony TR81 and a TRV33. Using RCA the image is visible and audio audible; only image is visible with S-video. I have changed AV to DV OUT. I want to record onto a miniDV tape - not use the passthrough feature (sending the digital signal to a Mac). Is this possible? Any guidance is much appreciated.
Thread: Hi8 to miniDV question
s-video carries no audio so use both the s-video plus the rca for audio
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Excellent - thank you. But there is another glitch which I should have mentioned earlier. I cannot record onto the TRV33. I can see the footage in the monitor, while the TRV33 is in PLAY mode. But if I change that to CAMERA/RECORD, it does not record. I am sure I am missing something very obvious.
see if there's an import setting or the like on the menu
No, there is nothing like this in the menu in CAMERA mode, nor in PLAY mode.
Here are the "dubbing" directions on P-94 of the TRV33 manual.Originally Posted by low613
First connect Hi8 camcorder with S-Video + RCA White and Red to A/V inputs on the TRV33. Don't connect Yellow.
http://www.kiva.org/about
Thank you - both - so much for your assistance. Works just fine.
Will the Sony Hi8 Miniplayer/MiniDV players (w/ TBC) work for VHS capture?
By DaveP56 in forum CapturingReplies: 1Last Post: 6th Feb 2011, 15:38 -
Audio Problems when transferring Hi8 to miniDV
By mrskunk in forum CapturingReplies: 0Last Post: 21st Oct 2009, 17:19 -
Hi8 takes MiniDV tapes??
By OM2 in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 26th May 2009, 05:23 -
DV (from VHS/Hi8/miniDV) -> HD. Expand color/luma? Bad idea?
By Colmino in forum Newbie / General discussionsReplies: 36Last Post: 24th Jun 2008, 16:34 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Oct 2007, 19:19
