I wish to keep the grain of the source when I convert to h264. I can do this, but the bitrate required is ridiculous. There were older experimental versions of x264 around which had "keep grain" switches but I can't figure out how this is accomplished in the newer builds.
Yucky Poo
"Quality is cool, but don't forget... Content is King!"
Grain acts like noise , and requires a higher bitrate
psy-trellis and psy-rd are the switches that enchance grain. For example
--psy-rd 1.1:0.5 would mean 1.1 for psy-rd and 0.5 for psy-trellis
The new preset system has a grain retention setting --tune grain for heavy grain sources. These are the settings when activated:
Recent builds use mb-tree which redistributes bits to more challenging scenes like action scenes. Many people tend to find it causes problems with fades. If the grain occurs in fade and dark sequences like your screenshot above, you might consider turning mb-tree rate control offOptimize for grainy content: deblock -2:-2, psy-rd 1:0.25, no-dct-decimate, ipratio 1.1, pbratio 1.1, aq-strength 0.5, deadzone-intra 6, deadzone-inter 6, qcomp 0.8
Thanks PDR, I'll give it a shot
Bumping up qcomp will probably keep more grain and fine detail, but it comes at a high bitrate cost. 0.7 is about as high as is comfortable for me. Increasing it weakens mbtree strength, since it moves closer to constant-quantizer encoding (which is qcomp=1.0).
Also, pbratio shouldn't have any effect when mbtree is enabled, so I wonder why it's set in that grain tuning.
How to remove grain in video
By skorpinok in forum Video ConversionReplies: 19Last Post: 13th Dec 2010, 21:06 -
The best way to remove grain?
By FatalX in forum EditingReplies: 6Last Post: 11th Nov 2010, 11:37 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
X264 encode switches/options retrieval
By padiwa in forum Video ConversionReplies: 2Last Post: 11th Jan 2010, 09:28 -
Plasma image retention
By Browncoat in forum Newbie / General discussionsReplies: 23Last Post: 7th Nov 2009, 11:45
Statistics
Newest guides
Latest tool updates
New media comments
