My goal is to transfer my camcorder's DV tape footage to my computer, edit it, then burn it to DVD while keeping max quality all the way but not going to crazy lengths to do so.
Does it matter what program I use to "capture" (or "transfer" as I learned from digitalfaq) the DV footage to my PC to then edit & author later?
Currently I use Pinnacle 12 to "capture" the footage to AVI and it results in around 13gb per hour. I know VirtualDub does capture to AVI, but is there any difference if it's just a "transfer" of footage in my case?
DV capture over IEEE-1394 is usually a stream capture to a DV-AVI file. When done correctly (without lost frames) the data in the DV-AVI file are identical to the DV tape (i.e. still first generation).Originally Posted by spup345
In that case, all DV capture is the same although other features differ. I like WinDV for basic capture. It is the most foolproof and has a buffer and frame loss warning.
Virtualdub is a different story. It decodes DV into RGB or Y,Cr,Cb using a DV codec (e.g. Cedodica DV codec ).
That is lossy.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
WinDV and use nothing else for cature....works ALL the time
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Thanks. That takes care of that.
You can also prevent/avoid frame drops by following this advice: http://www.digitalfaq.com/guides/vid...ped-frames.htm
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Editing DV footage with Pinnacle - Will "uncompressed" maintain q
By spup345 in forum EditingReplies: 8Last Post: 20th Jan 2010, 16:00 -
Sony Vegas 9.0, AVCHD/mds "ghosting" with Canon HG10 footage
By Woodserr in forum Video ConversionReplies: 33Last Post: 29th Jul 2009, 22:12 -
Picture "rolls" when trying to grab 60hz footage
By scully1888 in forum CapturingReplies: 4Last Post: 21st Dec 2007, 04:41
